Question about Compal EL81 Notebook
My compal hel 80 keeps shutting down as soon as windows boot up. Could it be the ac adapter.
  • Compal Master
  • 4,737 Answers
If it never goes forward after the Windows Boot Screen, then the problem must be with the software or drivers problem, Hard disk, Cpu Overheating, Ram failure or with the Windows Installed on your computer. To verify that the Adapter isn't the cause, please boot from the Battery, after the adapter is unplugged.
Your first solution would be cleaning the whole system system and check the components one by one. Remove the Hard disk, clean the interfaces/connectors and again reinstall it, do the same with the Ram (you can use cotton/soft brush dipped in Alcohol or spirit or acetone as cleaning material). Clean the cpu fan, blow away the dust and make sure there's no clogged dust on the Heat sink.
After you are done with the above steps, try boot into Safe Mode, if it's successful, then again try normal boot. If the problem persists, uninstall recently installed drivers or updates or softwares, run a system restore from the Safe mode and revert it to the previous state when it was working fine. Even if this doesn't fix your problem, you can narrow down the root of the cause, but there is chance that it could work for you.
Your last option is with the hard disk, try to boot from cd after inserting the Windows Cd (any windows xp or vista or win 7) and if you get positive effect, repair the windows with the cd that you had used during the installation of the current installed Operating System.
In case you don't get any positive results, then I would suggest you to call a Technician (Computer hardware engineer) or look for a service center.
Good luck.
Thanks for using FixYa.
Posted on Jul 09, 2010
  • Compal Master
  • 11,800 Answers
No. If it would have been the adapter it wouldn't have started at all. Your Windows is corrupted and you must reinstall to fix it. Use a Linux Live-CD to recover your files before that.
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
Hi i have come in to work and booted the pc and it didnt come on i have looked at the board and the little green light next to the seamen battrey is very dull and while its like that it will not boot and...
hi
i am not certain, you are referring to the NEC notebook. if so, try booting up with the AC adapter only
what model and type is the computer ?
if you are in North America, i can recommend you to a battery store near you.
Follow instructions:
1) make sure computer is off. remove the battery
2) power up the computer with AC adapter attached only
3) if it does boot up, shut it down.
4) re install the battery and boot it up without AC adapter
if the notebook does not boot up, then yes, you need a new battery for it
if the batter is 2 years old or more, you need new battery
send me 4 thumbs up please.
Jun 06, 2011 | NEC Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
How do I reformat the harddrive if windows wont load?? I have a virus and everything froze, so I tried rebooting windows with a cd rom so i could wipe the hard drive, but i get a message that windows...
That sounds like you have a very nasty virus that has infected the memory.
Switch off, unplug and remove the battery.
Using just the AC adapter, place your OS disk in the drive and as the laptop gets to the BIOS option, press F2 or whichever F button lets you in to set your master boot device as DVD/CD Rom.
close the laptop down and remove the AC Adapter.
Plug the AC Adapter back in and boot the laptop, that should get you into the CD ROM disk for formatting and replacing your system. I hope you remember to download all of the required drivers.
Hope this help.
Dec 12, 2010 | Gateway LT2021u Netbook
Compal RM CY25 Laptop. new battery won't charge.
Unfortunately, the charger socket in the motherboard does not drive electricity to the battery to get re-charge it. It is a typically motherboard problem(Do not confused with a power jack problem). I can not be repaired it.
Two options work always hook with power adapter or get ride of her.
Jan 30, 2010 | Computers & Internet
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Satellite A105-S1014 TOSHIBA
Sound you got a virus that corrupted a certain file in your Windows operating system. Try googling with a descriptive computer keep rebooting or something similar. Basically you need to replace that corrupted file and there are hints in the Internet on how to do this.
Oct 18, 2008 | Computers & Internet
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Compal EL81 Notebook Logo
186 people viewed this question
Top Compal Computers & Internet Experts
Phani Kiran...
Phani Kiran...
jd83854
Are you a Compal Computer and Internet Expert? Answer questions, earn points and help others
