Question about Intel Motherboard
Monitor hi monitor's power on but dispaly not shows,
  • 32 Answers
Check your connection at the back of the monitor and at the PC
Posted on Jul 09, 2010
Power on/off problem when i monitor power bottom on work properly next i monitor power off .again power bottom on then the power led blecking and no dispaly
switch could be bad. Just leave the monitor ON. When you shut down computer the monitor will just go to SLEEP.
Apr 05, 2014 | Computers & Internet
Va703m
This is a common indication that the power supply board has bad filter capacitors. When the capacitors go out the power board can not start up correctly so you get either a white screen, a flashing power light and no display, a flickering display or no power at all. The repair is easy, it just requires replacing the bad capacitors on the power supply board. About 10 minutes and a little soldering and your monitor should be as good as new. Here is a link to a repair kit with the correct parts to do the repair.
http://www.ccl-la.com/catalog/product_info.php?products_id=145
Apr 26, 2013 | ViewSonic VA703mb Monitor
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
Only one time show ok display on power on than convert black dispaly
This is an old monitor, I remember working on these many years ago.
Anyways, the backlight is bad. The CCFL bulb needs to be replaced.
It is cheaper to scour ebay or something to get another one if this is in a server tray than to get it fixed.
If not, just buy a new monitor. You'll see a world of difference in picture quality.
Oct 13, 2010 | Compaq TFT5000 15" LCD Monitor
"no signal" on monitor, my cpu fan is working fine but beep sound is not coming
Hi
Try this steps:-
1.Please check your power cables properly.
2.Remove the monitor cable from CPU and turn on the monitor and see are you getting the dispaly or not.
Oct 04, 2010 | Intel Motherboard
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Hi - Received a LG monitor, W53 Series as a gift.
in your laptop there is button press f5 or f6 to get dipaly on lg monitor or you can right click and go to display properties and set the dispaly.
Sep 08, 2009 | Computers & Internet
UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU LOCKED
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
Aug 18, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
The log on screen does not show up
No, it seems the monitor is not getting picture from the computer, check your cables, and you can try the monitor on another computer to see if the monitor works, if the monitor works then the problem is in the computer.
Nov 15, 2008 | SAMTRON 55V 15" CRT Monitor
Phillips monitor 150b3 no dispaly just power on
monitor on position and display show "AGING..."
plz solution
urjant
thanx
Feb 26, 2008 | Philips 150B3T 15" Flat Panel LCD Monitor
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
