Changing temp readout on Midea Air Con Controller from F to C
How do i change the temp readout on a Midea Air conditioner wall push button controller from F to C ??? (fahreneit to Centigrade )
Midea Model Number CCM04
The Owners manual supplied is absolutely useless and the temp readout on the Controller is in Fahreneit which we have to keep converting back to Centigrade ??? All the other same Units in the Villas are in Centigrade except ours ????
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Posted on Aug 17, 2010
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Air con wont start up. ? Flat battery
Should be a couple of tiny Phillips.
Dec 13, 2013 | Fujitsu 24C1 Air Conditioner
My sansui air con does not produce heat even if I set the temp at 32. I cant find the manual. What am I not doing right
I do not know what A/C unit you have but Heat Controller is a name. It would not suprised me the it doesn't have heat. Most window A/C don't.
Jun 30, 2011 | Heat Controller Room Air Conditioner
2001 land rover discovery change air conditioner temp readout from celsius to farenheit
To change the temperature reading from C to F (or vice versa), press and hold the recirculation button, then press the off button holding the switch down for 3 seconds or more until an audible beep is emitted. If the battery is disconnected and then reconnected, the temperature reading will revert to C. Turning the ignition on/off will not change the customer's set preference.
(See http://www.discotech.info/index.php?title=Climate_Control for more customer configuration options for the climate control)
Dec 28, 2009 | 2001 Land Rover Discovery Series II
Hi, I have a wall mount midea split a/c model- MSG-36HR that will only heat. when put in cool mode it only blow's room temp air and the outdoor unit won't run. On heat mode it works normally. I have cycled...
Most heat pumps are 'fail-safe to heat'. That is: the normal position of the valve which reverses the function is in the position which provides heat. The reversing valve must be powered to switch to the cooling position.
Although the lack of valve function could be a mechanically defective reversing valve - it's more likely to be an electrical issue. Start with checking for power at the reversing valve's coil. If it's powered unpower it - you will be able to hear the reversing valve distinctively
Oct 03, 2009 | Midea Heating & Cooling
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
242 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
