Question about Riso RZ390 Duplicator
Riso rz 590 what is the name of the little roller that pulls the paper through
    New Friend:
  • 34 Answers
Pick up roller the part number is 035-14303-001
Posted on Jul 16, 2010
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
Problema para Riso - Duplicadora RZ220 Copiadora Error message A-06-403 Mensaje de error A-06-403
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
Aug 09, 2010 | Riso RZ220 Duplicator
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
Fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
Feb 19, 2009 | Panasonic UF-590 Plain Paper Laser Fax
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
Riso Rz 220 copies are coming out to light.
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Oct 29, 2008 | Riso RZ220 Duplicator
83 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
