I have a Starlogic HD20W monitor. You turn it on and it almost immediately turns itsel***. Push the on/off switch to turn it off and push it again and the monitor comes on for a second. what could the problem be? thanks bill
I have this same problem, in fact, i've had this problem on and off for the past year. Randomly, the monitor would stay on for a period of time, then go blank again. Now, however, I cannot get it to stay lit at all. Weird that you and others have this same problem.
Posted on Jan 23, 2011
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
Where can i buy parts for a starlogic hd20w monitor
from monitor repair shop
ok bye.............
Nov 09, 2009 | Star Logic Monitor 11009515
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Help to find power cord
circut city or radio shack maybe a gamestop 2
Feb 01, 2009 | Computers & Internet
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Push button power broke Starlogic LCD 19"
My monitor Display show to wide.
Starlogic 19'
Nov 07, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
