Question about Goodman CLJ30AR32 Air Conditioner
Goodman 4 ton AC, unit outside shuts off only some of the times. It will cycle on and off 20/30 times then for whatever reason it stays running even after the inside unit shuts down
  • 674 Answers
The contactor in the outside unit may be sticking. Check the condition of the contacts and replace if necessary.
Posted on Jul 09, 2010
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I have a Goodman GPH1324H21A the fan comes on and the AC kicks on for a couple of minutes then shuts down what's wrong with it?
if it's 4 years old it doesn't have r22. Are BOTH fans running when ac shuts down? Inside unit or outside unit shuts down?
Jan 08, 2018 | Goodman GPH1324H21A WallWindow Air...
Hello, we had central air conditioner installed last October. We turned our unit on for the first time and the outside unit shuts down but the air handler continues to blow air and never shuts down. ...
Hello, if the blower motor runs continuously and does not shut off at tne thermostat then the relay on tne integrated control board is bad. Only option is to replace the control board
Jun 28, 2011 | Goodman CKL36AR36 Air Conditioner
I have a goodman CKJ42-1B air cond. unit. It keep tripping my AC breaker although continues to blow air - just not cool air. Once I turn OFF then ON the breaker the AC works fine for about a day. Then...
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Aug 06, 2010 | Goodman CKL36AR36 Air Conditioner
1 1/2 ton goodman outside unit made a hissing
Hello Scott,Your new ac is OVERCHARGED with freon.Shut it off,let it cool down and recover/remove freon.The compressor has an internal pressure valve that makes the (hiss).It will stop when the charge is adjusted.Call them back to do it.
Jul 31, 2010 | Goodman CKL36AR36 Air Conditioner
3 ton condensor and 2.5 air handler
I hate to use rules of thumb but 500sqft per ton depending on your windows and insulation. you are probably ok with a 2.5 ton however it will not work with a 3 ton outdoor unit as you have figured out. depending on how long that ac has been in you may want to replace it with a 2.5 ton due to the damage to the compressor valves because of the mis match. or if the indoor is newer and the original system may have been a 3 ton then i would replace the A/H. and be prepared to replace the outdoor if the valves are to far gone. If the trane is a new high effiency 2 and the goodman is just a 10 SEER you may be able to have a txv installed on the trane unit and a kickstart device outside. but only if its a high effiency but their again if the A/C fails you couldnt have a high effiency 3 ton you would have to drop down to 2.5,
Sep 22, 2009 | Heating & Cooling
Goodman heat pump 5 ton power problem
Sound like the outside unit is going to ground or the unit is over amping. Take and shut off the power to the unit and check all of the electrical connection for tightness. Don't forget to check the disconnect wires too since you shut it off at the breaker box. If you have a meter check to see if it''s live before you work on it. If it's all tight then call back the person that did the previous repair and tell them that he obviously missed something and the you feel that it should be a warranty call.
Dec 20, 2008 | Goodman CLQ36AR49 Air Conditioner
Hvac
dirty flame sensor
Oct 28, 2008 | Goodman Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CLJ30AR32 Air Conditioner Logo
107 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
