Question about Patton U2-1487 Floor / Box Fan
Where can I buy a rotary switch for a Patton U2 1879 floor fan?
    New Friend:
You can check with the local hardware store.
Posted on Nov 09, 2010
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
Oct 09, 2012 | Patton U2-1887HO Floor / Box Fan
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
Bad switch, how much is a replacement
these switches range from 10-20 dollars and are easy to find online search three speed rotary switch in google
Aug 24, 2010 | Patton U2-1487 Floor / Box Fan
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Wiring on a 3 speed rotary switch for a fan (cord type),the switch just broken and i want make a connection on wires for just to run at only one speed.
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
Sep 03, 2009 | Patton U2-1487 Floor / Box Fan
Replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip marinaman@aristotle.net
Jun 13, 2008 | Patton U2-1487 Floor / Box Fan
Motor seized
I just want to know if I can purchase a NEW motor and what the cost is?
Feb 24, 2008 | Patton U2-1487 Floor / Box Fan
Patton U2-1487 Floor / Box Fan Logo
609 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
