Question about Lenovo IdeaPad Y510 Notebook
Left button has popped out. Need to fix it back
    Scholar:
  • 50 Answers
If the button has popped out you can call LENOVO tech support dept and check your if your system still has a warranty for depot, they'll give you instruction on how to sent it to the depot via fedex free of cost.
Posted on Jul 28, 2010
How do I fix a stck button
This will be difficult but you'll have to open it up, and clear the spot out from dirt dry liquid clean it well WITHOUT WATER, and then either reposition it or get a new one in it's place.
Feb 22, 2013 | Audio Players & Recorders
The left click button is partially pushed down and is difficult to make it click
This is an easy fix:
Step 1: Find a flat tip screw driver, the smaller the better.
Step 2: Gently pry around the edges of the left click button on the touch pad. It should pop off easily, don't force it!
Step 3: When you get it off you should see a small nipple that the plastic button pushes down. Make sure the nipple is secure and free of debris.
Step 4: Gently snap the touch pad button back on.
That's it!
Nov 12, 2012 | ASUS K501J WXGA HD 15.6" LED Panel
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My left mouse button doesn't spring back but still works. It is constantly pressed down. any way to fix?
You may have a broken key, or the keyboard itself may need replacement. Find a reputable laptop technician (any decent mom&pop PC store should be able to help) to remove the key and inspect it.
-Jon
Oct 21, 2009 | Dell Inspiron 1525 Laptop Jet Black
Loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
Aug 17, 2009 | HP Pavilion DV4-1120US Laptop
Interior button no longer pops the trunk
i believe there is a switch in the trunk compartment to the left hand side that enables this button to function check that out....
Feb 11, 2009 | 2002 Mazda 626
How do you repair a keyboard button that has popped off
http://www.isoretail.com/store/proddetail.php?prod=13N9988 Is where you can buy a new keyboard. It's 22 dollars, I'd suggest that. Unless you have a way to press the key back in the slot you're done. You can burn a ton of time when the part's not that expensive. (yes you can replace it yourself)
Jan 01, 2009 | Gateway 7320GZ Notebook
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
FROZEN ZUNE 30G SCREEN
press and hold Back button plus up on the pad.
Lenovo IdeaPad Y510 Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
