Question about IBM Travelstar 4GN (DKLA22160) Hard Drive
Tekla structure installing method
Tekla structure v15 crack version installing method
Lost driver disc for camara vivitar v15 digital camara need software down load where do i go to cet free.
http://www.vivitar.com/products/1/digital-cameras/23/vivicam-v15
Click the "Vivitar Experience Software" link.
Oct 31, 2010 | Vivitar ViviCam V15 Digital Camera
I can not find the drivers for vivitar v15
get the manual and drivers at http://manualfox.com/link/vivitar.htm
Dec 26, 2009 | Vivitar ViviCam V15 Digital Camera
Vivitar freelance V15 digital camera...HELP
OK Tested solution. pay attention please.
1. At this website you may download the Vivitar V15 Manual. http://www.retrevo.com/pdf/23576bh245/2/Introduction#q=Vivitar+V15
2. Notice device driver program PhoTags Express has "Sakar" in upper right corner. Sakar makes "inexpensive" cameras. I chose a camera most similar to V15 and download its Driver here.
http://www.sakar.com/productdetail.aspx?id=2275&categoryid=170
3. Driver install occurs normally with a restart of computer. V15 stil not recognized YET so next.
4.Get to Device Manager = press "Windows" keypad button" & "Pause" keypad button at same time. At system properties Press HARDWARE tab and the DEVICE Manager.
5. Double click camera device (may have yellow ? )
6.click DRIVER tab
7. click UPDATE Driver
8.choose NO, NOT At This Time, click NEXT
9.choose INSTALL from specific location
10. click Don't Search, I WILL CHOOSE Driver to Install
11.choose "Imaging Device"
12. choose DUAL MODE CAMERA (make certain check box has check)
13.Driver for V15 Dual Mode Camera INSTALLS.
14. Click FINISH
15. may have to restart.
16. CAmera should now show in My Computer as Dual Mode Camera
Nov 11, 2009 | Cameras
I have problem with my desktop.
Try to follow some of these methods:
First Method
  1. Lauch Windows Task Manager.
  2. End wgatray.exe process in Task Manager.
  3. Restart Windows XP in Safe Mode.
  4. Delete WgaTray.exe from c:\Windows\System32.
  5. Delete WgaTray.exe from c:\Windows\System32\dllcache.
  6. Lauch RegEdit.
  7. Browse to the following location:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
    Windows NT\CurrentVersion\Winlogon\Notify
  8. Delete the folder ‘WgaLogon’ and all its contents
  9. Reboot Windows XP.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
Second Method
Another alternative suggested by dman is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Note: Again, you may be prompted again to install WGA Notification, so it must be bypassed.
Third Method updated
This method involves using a cracked version of LegitCheckControl.dll to replace the original copy of LegitCheckControl.dll, and thus bypass the WGA validation and make Microsoft believes that your copy of Windows is genuine. To get rid of WGA Notifications warning messages, the patched version of WgaLogon.dll and WgaTray.exe to replace the existing files.
To apply the patch by replacing the files manually, try to end the respective processes in the Task Manager before deleting the existing files. Most likely is you will have to restart your PC in Safe Mode in order to replacing the original copy of LegitCheckControl.dll and related files. However, there has been automatic updater and even cracked WGA installer that automatically apply the patched version of WGA files.
Latest Update for WGA version 1.5.708.0 latest
Download cracked and patched version of LegitCheckControl.dll with thanks to Danny.
Latest Update for WGA version 1.5.554.0 latest
Download cracked and patched version of LegitCheckControl.dll, WgaLogon.dll and WgaTray.exe for v1.5.554.0 of Windows Genuine Advantage Validation Tool and WGA Notifications.
rate me if this works.
Mar 22, 2009 | Microsoft Windows XP Professional With...
Getting nonerasable warning from Microsoft!!!!!!!
You seem to be a victim to piracy from your local vendor. You can report him to Microsoft and receive a finder’s fee, which isn’t going to cover the cost of new Windows XP. So here are some alternatives.
With new release of WGA, some methods no longer works, and some has been updated. Several methods that has certain success on certain people, you may try until you success.
Official Method by Microsoft - more information here. http://www.mydigitallife.info/2006/06/28/official-ways-to-disable-or-manually-uninstall-the-microsoft-windows-genuine-advantage-notifications-from-microsoft/
or:
First Method
  6. Lauch RegEdit.
Second Method
Another alternative is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Download http://www.mydigitallife.info/2006/09/27/remove-bypass-patch-and-disable-microsoft-windows-genuine-advantage-wga-validation-version-157080-with-legitcheckcontroldll-crack/
Download http://www.mydigitallife.info/2006/10/08/crack-and-patch-to-bypass-and-disable-wga-genuine-windows-validation-and-notifications-version-155540/ of Windows Genuine Advantage Validation Tool and WGA Notifications.
In the short of it, sometimes it worth to just get a legitimate copy so your problem will go away. Unfortunetely being the victim really sucks, because this will for every be a problem if you do any updating of MS software. If you look around (eBay etc) you may find some pretty good deals on Windows XP.
My best of luck to you.
Mark
Dec 31, 2008 | Microsoft Windows XP Professional for PC
Repairing cracked front windshield
Hi there!
Yes there is.
Specialist firms deal with windscreen repair, and may be covered by your insurance policy.
The method for chips involves creating a vacuum over the damage, then injecting clear resin. This sets and is then polished off flat again.
For cracks in one layer, the end of the crack is hollow ground, and a disc of glass is bonded in, then the crack is either ground out and filled, or just filled as a chip would be.
Ask several windscreen repair companies for a quote before working.
If the crack is severe, it may not be possible due to weakening of a major structure. Also if water has entered the crack, then damage of the mid layer cannot be repaired, and will remain foggy or white.
Jun 19, 2008 | 2000 Chevrolet Malibu
Computers & Internet Logo
197 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
