Question about Philips Lands Phones
Philips cordless phone model se450 duo keeps flashing searching
Philips cordless phone model se450 duo keeps flashing ''searching'' never set a pin and it will not accept 0000
SOURCE: Philips CD245 Cordless Twin
just one phone displaying unregistered
Posted on Oct 10, 2008
richa33
  • 71 Answers
SOURCE: Philips CD125 Twin Cordless Phone "Searching" problem
Maybe, RF amplifier chip die or antenna broken.
Posted on Jan 21, 2009
  • 6 Answers
SOURCE: my Philips Cordless phone answer
The handset is not ‘registered’ with the based unit.
By default, the Master PIN is 0000.
  1. On the base station, press and hold The paging key for approximately 5 seconds.
  2. On the handset, press Menu key,
  3. scroll : to ADVANCE SET and press (Menu) OK,
  4. scroll : to REGISTRATION and press (Menu) OK.
    Note: If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
  5. Enter the Master PIN when prompted and press (Menu) OK to confirm.
Posted on Mar 20, 2009
Schmead10
  • 650 Answers
SOURCE: I cannont register a ATT 2042 cordless phone to
Are you sure it's a 2042...I found 2402 manual http://www.retrevo.com/samples/AT%26T-Telephone-manuals.html
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Posted on Jan 24, 2010
Philips cordless phone se 455
CANON IR2520 ERROR E000000
Nov 11, 2013 | Lands Phones
The battery icon which shows battery is full, keeps flashing continuously on Philips CD565 Duo
I would return it to the manufacture, you have described two different problems, this is clearly a manufacture defect.
Mar 29, 2012 | Computers & Internet
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
Cd135 philips.
  1. Enter the Master PIN when prompted and press (Menu) OK to confirm.
http://www.p4c.philips.com/files/c/cd2452b_05/cd2452b_05_dfu_eng.pdf
Mar 18, 2009 | Philips 2252 Twin Cordless Phone
Manual for Philips CD130 DUO missing
I am not 100% sure that this is the model you are looking for, but I found a manual on the UK page of Philips:
http://www.p4c.philips.com/files/c/cd1301s_05/cd1301s_05_dfu_eng.pdf
Have a look and let me know if that helped you!
Although it might not be the exact same model, it might have the information you are looking for.
The complete list can be found here.
Feb 07, 2009 | Uniden Cordless Phone
Phillips CD130 Cordless Phone
Harry, take the batteries out the back for 2 mins.When you put them back it will refresh the phone and should be ok
Steve
Aug 13, 2008 | Uniden Cordless Phone
My Philips Cordless phone answer machine CD2452B CD2452B/05 keeps flashing the word searching and it will not work
Jul 08, 2008 | Lands Phones
GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
Jun 09, 2008 | Uniden Cordless Phone
Philips CD135 Twin Cordless Phone
Disassembly the battery pack, and power on after that.
Oct 28, 2007 | Philips DECT 2252S Cordless Phone
Lands Phones Logo
445 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
