Question about Sony Ericsson Cyber-shot C905 Cell Phone
I know it's on but it's blank (dark) If i used a flash light i could see everything. Like a black out. I was told it need a new flex other's said lcd. Im not sure what's wrong with it. Please help.
I gt same prob how can u fix dis
Posted on Jul 14, 2010
Gps screen not working
Hi your problem can be caused by any fuse that supplements the power to screen check voltages that feed the screen.
also can be your back light is working a way to prove your back light is , turning on the radio in a dark place and bring a flashlight and tries to see something on the display if something is provably which is only your back light and if it is not that the new screen does not works
Another reason could be that the flex cable that you are using that was connected to your old screen and this defective, also check the connection of the flex cable on the screen may be that in the process of Assembly is disconnected.
Jan 13, 2014 | GPS
The films that are being processed are coming out blank, how do you fix this?
If you are shooting with the new film from the Impossible Project, you need to turn the button which makes the photos come out light or dark all the way to the dark side. At most cameras this little button is next to the lense. It's hollow and you should be able to see a little lense inside of it. You probably took your photos with the button to the light side, which causes your photos to come out lighter (this was useful for taking photos with a dark background). I also recommend you to buy a flash for your camera. I use a Polaroid as well and I noticed how my photos didn't get overexposed when I used my flash. Odd isn't it.
Oct 16, 2013 | Konica Photography
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
I have blank screen on my motorola razor. It lights up but no images is there anything I can do?
Hi,blank screen for Motorola phones are usually caused by the flex of the phone.
Sometimes it might appear in white screen display too.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
The screen blank might also be from the screen itself. But to confirm if it's the screen,you willneed to replace the flex first,and after replacingthe flex,if it doesn't display,then you will know that it's the screen that is damaged.
Hope it helps.
Thanks for using fixya...
May 28, 2011 | Motorola Mobility RAZR V3m Cellular Phone
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
My phone is switching on ok and the screen is lighting up but nothing is happening.One minute it was working, the next it went blank. I have been told that it needs a new screen but I dont know why. It...
Hello
I suspect a flex problem
The flex is what connects the screen of the phone to the board of the phone.
what you are experiencing is common with all flip phones and slide phones, the more you flip and slide these type of phones,the flex gets weaker and that may be the cause of the blank screen
What you should do is;
Open your phone,you will see a plasticlike cable connecting your phone screen to the board of your phone(that is the flex)
Remove the flex and fix it back carefully, you should hear a click sound.
Close your phone and switch it on you wont have a blank screen anymore.
if you cant do this yourself,get a person with experience to do it for you
Thank you for visiting fixya
Mar 01, 2010 | Nokia 6270 Cellular Phone
Just a black screen
hi im josh may i help you? Friend your phone appears flashing bright light then standby light. I diagnose this as a hardware problem particularly the flex connection from LCD to mainboard.If is difficlut to say that this is a software problem because you've said that you can operate the music and other pheriphrals.Because when software is corrupted or damage it will not make the whole phone for sure but is not so. I'm sure the connection poblem is the problem.maybe it just a disconnected or loosen connection problem. all you have to do is luuk for somebody know some electronic works then let him or you open the phone this just firmly attached or mount properl the connection of LCD and mainboard it will solve the problem for sure or you may do the job to the moble phone technicians in you neighborhood. if you need some assistance how to disassemble the phone you may log on to sonyericson.com. thats all friend good luck
Mar 07, 2009 | Sony Ericsson W850i Cellular Phone
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Razr v3 flex cable connected but screen is still black
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Jul 15, 2008 | Motorola Mobility RAZR V3
Dark pictures with flash
I had this problem before, sent it off to have it repaired 1 year ago, and now have it again. Just to make sure it's the same problem, here's a description: The flash seems to be out of sync with the shutter. Using the flash in medium or low light (in auto mode) makes the picture darker than not using a flash at all. It ruins the picture. In a completely dark room, even though the flash fires, the pictures comes out pitch black. The problem is the flash unit -- it needs to be replaced. If your camera is under warranty, Canon will replace it for free. (You pay only to ship it to them.) (You might try what they told me to try before I shipped it off, and that was to reset the camera by pushing and holding the menu button until it resets. Didn't do anything for mine, but who knows.) If it's not under warranty, Canon will offer to replace it with a refurbished newer model for a discounted price. That's my situation now, because the problem has come back. I did come across a posting that described how to replace the flash unit yourself -- it involves taking the camera apart, but looks doable. (Sorry, I don't have the link handy and I'm not sure if I can find it back.) The problem is, I don't know where to get the part. Canon has been no help on this. Anyone know where I can get a Canon flash unit for the A85? Hope this helps, and good luck.
Jul 28, 2006 | Canon PowerShot A85 Digital Camera
Sony Ericsson Cyber-shot C905 Cell Phone Logo
66 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
