Question about Samsung SyncMaster 510N 15" LCD Monitor
Not optimun 1020x768 - Samsung SyncMaster 510N 15" LCD Monitor
    Problem Solver:
  • 7 Answers
Vapor lock in lr 2
1) please test any wires connector for dirty, corroded, loose, break or open use the VOM for to do it. Otherwise you must RUN the scanner and computer test for get optimun results in any repair shop car.
2) see the diagram troubleshooting for fix it.
God bless you
7_9_2012_1_51_23_pm.jpg7_9_2012_1_51_46_pm.jpg7_9_2012_1_52_21_pm.gif7_9_2012_1_52_43_pm.gif7_9_2012_1_53_32_pm.jpg
Jul 09, 2012 | 2008 Land Rover LR2
I have a Samsung Sync master T220p monitor and i have a problem with games that can not support 1920x1200 resolution. I received this Error : Not optimum mode recommended.
u need to fix the resolution 1020x768 pixel and properly install VGA driver.if u have any problem after that plz install a graphic card on your pc
May 27, 2011 | Computers & Internet
Cannot display video mode optimun resolution 1280 x 60hz
In this case the graphics card you have is not powerful enough to handle the monitor's optimal resolution. This means that you will have to replace your graphics card if you hope to reach the resolution your monitor was designed for
May 13, 2011 | Dell Computers & Internet
Every time I turn on my computer, the screen shows a box saying not optimun mode reccomended mode blah blah... plz help me solve this!
To fix this you should boot into safe mode and lower your display resolution and then after rebooting into normal mode set it to the LCD's correct native resolution and all should be fine.
Dec 15, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Linksys WRT160N PROBLEM... PLEASE HELP...
Some time what happer router will start blocking the data , in that case what you have to do is that you need to reconfigure the linksys router . First press the reset button for 30 sec , then remove the power for 30 sec and now your router is ready to reconfigure with your setup disk .
if you dont have the setup disk , i am pasting some router reconfiguration steps and i am sure that will help you out .
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection.
Apr 11, 2009 | Linksys WRT160N Wireless Router
Help
its possible that the inverter in the screen is failing, I recommend you take the screen to a tech to be checked whats the problem with it.
noting more I can do.. from other side of the world with text :-)
May 02, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Sasung 913n monitor
Same here. The unplug/inplug of the monitor seems to be the workaround. For now, I boot up Windows with the 913 unplugged and connect it after a couple of minutes when Windows has booted up. As mentioned before, this bug only happened to me after shifting to a PCIe card, Nvidia 6600 LE driver.
Dec 29, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung 913n
can anyone tell me were i can download drivers for samsung 913n monitor please thanx carlos
Dec 17, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 510N 15" LCD Monitor Logo
32 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
