Question about Microwave Ovens
I got a whirlpool microwave Model GH7145XFQ1. Our house fuse tripped and when I turned it back on the microwave has no lights at all.
  • mmall89625 Apr 24, 2008
    That is what I did and it is working fine now, though I had a hard time finding where the fuse is and how to take it out and place another to replace it.
  • 328 Answers
Have you changed the fuse in the plug of your microwave oven?
Posted on Apr 19, 2008
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
Oct 09, 2010 | Viking DMOR205SS Microwave Oven
What does a small d mean on the digital display? The microwave is not warming food. The model number is GH7145CFQ. Thanks
I'm assuming you mean model GH7145XFQ1?
It may be in "demo" mode or the door may not be shut properly, or the door switch or door switch mount may have a problem.
The owner's manual for the GH7145XFQ1 (here) doesn't address this.
I would suggest that you unplug it for a couple of minutes, then plug it back in and set the clock. The is called a hard reset, and it may be what it needs.
If it still does this, then the door switch or its mount have a problem.
Our file on door switch trouble is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Good luck.
Jun 19, 2010 | Whirlpool MH7140XF Microwave Oven
Turned light on. Several minutes later the light
Your unit may employ a switching power supply and these have a tendency to cease operation without warning and servicing these may require training and a piece of specialized equipment.
With the unit unplugged, after an hour or two, it is safe to open the housing and check for an internal fuse which could have failed.
If typical, these will be in a tubular ceramic housing about 1 1/2" long and 1/4" in diameter and can be purchased at most hardware stores.
Sep 27, 2009 | Whirlpool GH7155XHS Microwave Oven
My Model MH7140XFB-1 over the overn Whirlpool
There is an internal fuse. The cause for it blowing will have to be determined.
eric
Aug 06, 2009 | Whirlpool Microwave Ovens
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Now power to microwave
Check the AC fuse and the Primary winding of the Low voltage Transformer.
Jun 27, 2009 | GE JE1540 Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
