Question about Samsung SGH-e315
How do you put on the ringtone on this phone?
I can get the phone to vibrate. But how do i get it to ring?
    Scholar:
  • 158 Answers
Hi..
Follow this
  1. Press the left soft key for Menu
  2. Choose Settings (9)
  3. Choose Sound settings (4)
  4. Choose Ring tone (1)
  5. Choose the desired ringtone and press the left soft key for Select
Refer this link for all the setting for ur phone..
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=557&AT_ID=24431&PROD_SUB_ID=560&PROD_ID=602#Sounds
Hope this helps
Good Luck:-)
Posted on Jul 09, 2010
Lg neon will not ring or vibrate
If you have made sure it's set to ring and/or vibrate and it's still not working, then turn off your phone and take out the battery. Put the battery back in and turn it on, then see if it works. This will probably fix the issue. If you haven't made sure it's set to ring/vibrate, you can do so by going to "Menu" > "Settings" > "Audio & Ringtones" > "Ringtone" > "Volume" and make sure the volume is up and not on silent. You can also quickly adjust this by the up and down arrow buttons on the side of your phone without having to go to the menu. I hope this helps :)
Apr 29, 2011 | LG Neon GT365 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
Cant get the phone to ring. it is set to vibrate & ring but only vibrates
Set the ******** off and see if it rings otherwise try any ringtone as your default callertune and observe if the speakers ring. If not then best to take it to a technician...........sodeep
May 04, 2009 | Motorola Mobility W375 Cellular Phone
Lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Jan 12, 2009 | LG Shine CU720 Cellular Phone
Ring tone vs vibrate
There is no option to turn off the ringtone. You're not doing anything wrong. The only way to turn off the ringtone is to use the volume button to turn the sound off or to vibrate, or using the hot key (#) to go to "Vibrate Only Activated". I hope this explains what you wanted to know.
Aug 19, 2008 | Samsung SCH-u340 Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Samsung SGH-e315 Logo
37 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
