Question about HP 2159M Monitor
HP 2159 Screen Color
Hey so i plugged in my moniter and it looked perfect for about an hour when i turned it off for the first time. Upon restarting it the screen went through auto-adjusting and no matter what I do in terms of unplugging it restarting the machine installing new drivers the auto-adjust always saturates the screen in blue. Suggestions?
scottyfixit
  • 186 Answers
SOURCE: Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Posted on Jun 21, 2008
SOURCE: Auto Adjustment keeps turning on every few seconds
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
Posted on Jan 11, 2009
  • 285 Answers
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Posted on Jun 09, 2009
  • 92 Answers
SOURCE: My HP w1907 won't stop popping up 'Auto Adjustment in Progress'
Something seems to be triggering it to restart, these are some of the things you can try. Make sure your video cable and power cord are secure on both ends. If you have video card make sure it is secure in its socket. Try plugging the power cord into a different outlet. Try it on another computer if possible. If you find nothing with these ideas I would send it back if it is under warranty the power supply seems to be dropping out.
Posted on Aug 21, 2009
  • 120 Answers
SOURCE: Auto Adjusting in progress keeps popping up?
Might be a loose connection, a bad cable, or a bad video card. I'd try the monitor on a different computer--even a laptop. Should give you an answer as to what's wrong. With the laptop, reboot it with the video cable attached.
Posted on Jun 18, 2010
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
MY HP MONITOR 2159 WONT POWER UP
have you tried other cables and outlets? if so, hate to say the capcitors are blown inside and it needs to be replaced. when you do get new panel, always turn it off when your not at your pc. even so it goes to sleep, there is still a current running through the capacitors because when you move the mouse it wakes up. these capacitor have like a 0000-40000- hour life span.
should have asked, do you get a light? is the vga cable plugged into pc?
if this helps please take time to rate
Feb 01, 2013 | HP 2159M Monitor
Hey i have a netbook ACER 532H-2527, and sometimes it gets white but turn back, but now he always is white, but if i connect to a LCD monitor it works
hi.
if u have try to external moniter and working perfect, that mean your lcd screen problems and need to change.
regards
Jul 02, 2011 | Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
HP Pavillion DV9000
Howdy,
Like you said if you purchase it 5 month ago it should still be under the warranty. if i were you i will go that route
Dec 30, 2008 | HP Pavilion dv9000z Notebook
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
TV won't shut off
Sounds like color wheel BP96-00250A. Have installed by professional $350 ish
Aug 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
HP 2159M Monitor Logo
51 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
