Question about Vacuums
I need a new head or good second hand piece for my hero 1600 hover vacuum
  • 328 Answers
The Hero 1600 should use 32mm type floor fittings which means on EBay you can pick up just about any type of floor tool which is suitable for most Hoover, Electrolux and Morphy Richards/Goblin appliances. This means you can use other branded tools and floor heads just by their fitment rather than the name.
EBay is a lot cheaper than having to order a brand new one from Hoover themselves. Alternatively try any floorcare repair shops who offer additional tools which can be purchased. 9 times out of 10 they will have a floor head which is similar to the one which has broken on yours.
Posted on Apr 19, 2008
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Loss in suction?
I think, it's a "safety" vacuum release valve to cool the motor when the suction from the vacuum head is blocked.
Please clear blockage in the suction head.
Dec 24, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Hoover telios 1600 dismantling
Remove the 4 screws in the Dust Bag compartment.
Remove the Power button and Cord-rewind botton. This involves using a screwdriver or knife to open/undo a plastic clip located under the bittons near the gril in the top-centre-back of the hover.
When holding the clip back, slide the button towards the bottom of the hover (IE: away from the bag compartment) till it pops out (this can be fiddley).
This will then reveal 4 more screws (within the springs and near the grill).
Then prise the hover open to reveal the motor and power-switch.
Mar 25, 2012 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I pulled the wand out of my dyson ball to hover the furniture and now i cant get it back in what do i do?
You should be able to resolve this issue by referring to the user guide supplied with your machine. Here's a link which you may find useful if you don't have the user guide to hand: http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_uk_manual_120710.pdf
If you're still having problems, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some simple checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Mar 04, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
The power head will not turn. I tried to reset by pushing the red reset button and nothing happened. I could not depress it.
If the button could not be depressed, it was most likely not tripped.
First, check to see that the drive belts are on the machine and have tension on the roller for the power head. Second, check to see that you can turn the brush on the power head by hand. If you can not, you need to remove it and clean it of any debris, paying special attention to the two end pieces that hold it in place. If possible, squirt a little WD40 on these end pieces to make sure they are loose and can be turned by hand. Check the connections that power the motor on the power head.
Let me know if you have any trouble and I will gladly help you further. I do not charge for my assistance.
Paul
Sep 18, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hover steam vac Model #F5897-900
When I use my Hover Steam Vac, it smells like rubber is burning. How do I fix this?
Jun 16, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Need to know how to use hand tool...need manual.
Manuals at www.hover.com. You'll need the model number which is located on the back of your machine.
May 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Nov 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
