Question about Sony PlayStation Portable (PSP) Console
My psp wont turn on
Hi im im having the same problem with my psp, it turns on with the power cord, but as soon as i unplug it it turns off. Do i have to restore my battery or somthing with pandora. i don't have a second psp. so is there away of fixing the problem. my psp works fine, just dont work with out the cord pluged into it. its really anoying. please help thnx
  • 1 more comment
  • Marx_2k7 Apr 19, 2008
    and by the way im using my charger to turn on my psp but it still wont turn on is there a problem with the software or the hardware?
    and i was charging it overnight before it happen i played it then turn t off then charging it overnight was it the cause of the problem if it is pls tell me how to fix it i really luv my psp but now i cant play on it anymore :-( (crying)
  • Anonymous Jul 20, 2008
    i used a 2wire charger and now it wont turn on i'v taken out the battery twice but still
I WAS UPGRADING MY PSP AND IT SAID NOT TO TURN IT OFF AND I TOOK THE BATTERYOUT SO WHEN I PUT IT BACK ON IT WOULDNT TURN ON ANYMORE SO WHAT SHOULD I DO??I TRIED THE BATTERY ON ANOTHER PSP AND THE BATTERY IS FIND, I EVEN PUT ANOTHER BATTERY ON IT BUT IT WONT WORK
Posted on May 03, 2010
    Guru:
  • 134 Answers
First turn on psp with charger, and check your battery information under setting menu, see at battry status, if the status "RECHARGER" ;; there is a problem with psp software. Otherwise if the battery not detected, the problem with the hardware.... the battery fuse has burn.
of the time I find that there is something stuck, with psp id storage key. some of the key are used by battery switching disappear of psp system software, you can copy the key by another psp, but it's very dangerous! you can get full brick & your psp will malfunction anymore.
You can use PUMS v4, don't use previous version, because you'll haven't a backup of your original keys. and always to make a backup to your pc.
I hope this help.
Posted on Jun 11, 2008
Posted on Apr 21, 2008
I have my psp plugged in to the power cord for over a day, still not charged and it wont turn on at all. why ?? please help!!!
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Jul 13, 2010 | Sony PlayStation Portable (PSP) Console
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
Hi Hoping some one can help me I have an acer
U ARE HAVING PROBLEM WITH UR POWER CORD OR YOUR BATTERY
Jul 15, 2009 | Acer Aspire 4520-5582 Notebook
My psp wont turn on
Your PSP has just bricked. It may cause an error while you're upgrading your PSP or while playing the game.
Try this:
1. Pull the battery out.
2. Let it turn on while charging.
3. If your PSP LED power indicator turned on for 10-20 secs and the screen not turn on, it means you're really bricked it.
4. So what do you do?
5. You need extra PSP for making pandora battery and jigkick memory stick.
6. You'll need this link: http://www.psp-hacks.com/2007/10/16/pandoras-ultimate-magic-stick-installer/
If there' any questions, you can PM me everytime. =]
Jul 07, 2009 | Sony PlayStation Portable (PSP) Console
I was updateing my psp when the power went out and noe it wont...
did u try to press the little square button on the bottom of the console next to the music note?
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
My psp will not work without ac adapter
change the battery as soon as possible to prevent malfunctioning. because the problem is on the battery
Apr 02, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Philips HDTV wont turn on
    If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
    Jun 27, 2008 | Philips 60PP9202 60" Rear Projection...
    My screen wont turn on
    u have a failed reader chip or a dead screen! return the device as soon as u can remember u a actually don't need a slip for proof of purchase! the store generally must have record of transactions, just have the date and time of purchase and they by LAW must have a record of it. so get it swapped over
    Jan 31, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    215 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
