Question about Garmin Nuvi 760 Handheld GPS Receiver
I lost all voice prompts on my Garmin Nuvi 760. If I use the FM band, it works, and the volume works for keystrokes. Is there a fix for this?
  • 67 Answers
You will just need to de activate the FM transmitter to do that press the volume button at the bottom right hand corner of the main menu and uncheck the box that says something about the FM transmitter
Posted on Jul 09, 2010
Lost all voice prompts and in bluetooth mode voice is garbled
Go to Tools.....Settings....Language.... under Voice make sure Language with ( TTS ) is chosen
If that is ok then look at this...
Press Volume Icon.... if a checkmark in Mute remove it
if no checkmark then on the bottom of the screen you will see FM TRANS press
Does Enable FM Transmitter have a check mark? if so remove it and check sound
May 30, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
The voice is just not working, all else is fine, no, the mute is not on...??
Do you have the unit set to internal speaker or FM Transmitter? Go to the Volume section from the menu, FM Trans, disable FM Transmitter.
Feb 13, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin nuvi 760 suddenly lost it's voice and I have gone into tools and checked the voice and it is at 100% and the fm transmitter is off and the mute is off. Now what?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Assuming you have all the features on, try this
You will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Dec 01, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Voice direction is gone on my nuvi 760. What is the solution.
You probably lost all your TTS voice files or your speaker is not working. Connect Garmin to PC and run WebUpdater from Garmin and it will put everything back in.
Oct 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
There is no sound on my nuvi 760
I had the same problem! When I went under Settings/Language/ there was no voice that the machine could find! It is. I think a firmware bug or something like that.   You have to reset the 760 by holding the on-off switch on the left position for more than 8 seconds. After that you will have to choose the Language of your choice again. Let us see what will the next software upgrade brings us as a better solution.
Dec 21, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
No sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Dec 20, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
Sep 03, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Aug 10, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
221 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
