Question about Maytag Electronic Portable Air Conditioner Heat
I have portable 9000 btu and vented but it wont cool room below
Wont cool small bedroom below 77 degrees
  • Maytag Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Mr slim unit in bedroom 9kbtu - room 11x12'- is humid, awful
Lets clarify. DRY mode only dehumidifes that air and does not cool. Cool is used for cooling. Dry mode doesn't normally have temp control; it is automatically set by the unit. I think 9000btu is a big unit for the room; it is overkill. I would switch to a 5000btu unit. it cannot be fixed and the BR unit needs to be uninstalled and the new unit needs to be re-installed. The price of commisioning, de-commisioning and new unit is something in which you will have to pay.
I take the time to answer your questions, so please rate me.
Thankyou
Mat
Aug 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Maytag Electronic Portable Air Conditioner Heat Logo
545 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
