Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Can chlorine be added to the saltwater intex system if salt has already been added
  • 297 Answers
It can be added and also regular house hold bleach
why would you need more chlorine?
If you are needing more then something is wrong
If your salt content is not 3000ppm or more but not above 3800ppm then you are not going to be able to generate enough chlorine
Also you should be using a stabilizer that help hold chlorine content
Posted on Jul 09, 2010
  • mark Gianotto Aug 09, 2010
    would have been nice of you to use the rating system after receiving the expert answer to your question!
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Why does my salt level get low
You can get a false low salt reading if your chlorinator cell is very dirty. Before adding more salt clean the chlorinator cell as per your maintenance manual.
Sep 01, 2012 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Where do i add salt to my intex automatic salt water system
Ad salt right in the pool water. Filter and brush around to disolve. Do not try to generate chlorine for 12 hours or so.
Make sure your salt content is as close to 3000ppm as possible
Jun 16, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
639 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
