Question about Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner wont turn on...thermostat kicks on and i feel air but outside unit wont turn on..what should i check??
  • Marc Yoskowitz
    Marc Yoskowitz Jul 09, 2010
    is that something i can change...cause i checked the breaker boxes seems to be ok
    Sergeant:
  • 338 Answers
Have you check the outside breaker box? If thats not it then its probably the contactor.
Posted on Jul 09, 2010
2 Suggested Answers
  • 54 Answers
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Ruud achiever seer 10 air condioner not blowing cool air
need more info, touch the copper lines going into the unit do u feel any flow? Go outside do you see any fans turning? number of things you can do. Get back to me
Aug 12, 2011 | Heating & Cooling
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
Ruud achiever 10 seer air conditioner has weak airflow, I changed the filter and one of the coils on inside unit is frozen
Turn the unit off and give it time to thaw. A hair dryer can speed this process along. How did the filter look? When the coil has thawed check to see if it is dirty. Also make sure your indoor fan is running and all the covers are on the air handler. A weak capacitor will make the fan run slow. Let me know what you find.
Aug 24, 2010 | Ruud Matching Split Air Conditioner
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UBHC Air Conditioner Logo
921 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
