Question about Samsung Digimax L730 Digital Camera
Camera just won't turn on!! :)
Hi!
my samsung L730 will not turn on. i thought the battery was dead, so i tried to charge it - i am doing everything the way it says to and the charging light wont come on.
SO it wont charge, and it wont turn on.
Please please please help me. i would appreciate it so much. the camera is only about three weeks old!
Thanks so much. Have a nice day:)
  • Nrk1 Apr 28, 2008
    Same problem - just won't switch on.
  • mama1961 May 06, 2008
    I have the same exact problem
  • 477 Answers
Katie take it back to where you got it places like best but some time will just give you another camera no questions asked.
Posted on Apr 19, 2008
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
Hello Sir / Madam, I've got a Samsung Camera L730, 7.2 mega pixel, the problem is while charging, 1st it showed red LED light ( as usual ), then immediately an orange light starts blinking (as per...
Do you have change a Samsung L730 battery and to see if it can be charged? If you charge the battery in camera. It seems something wrong with the build-in charger core. If the camera all are OK beside charge battery, you can charge your Samsung L730 battery with a battery charger, and if your Li-ion battery is over discharged for a long time, it's bad for it. As your camera has been used for 2 years and it maybe not in warranty. To change build-in charger core should be expensive.
Apr 29, 2011 | Cameras
Samsung l730 not charging up
Do you have other set of battery's?
Feb 08, 2011 | Samsung Digimax L730 Digital Camera
How to charge My Samsung L730
Here is the owners manual for your camera. Pages 13-15 detail how to connect it for charging/recharging the battery.
http://downloadcenter.samsung.com/content/UM/200802/20080221092928218_L830_L730_English.pdf
Jan 09, 2009 | Samsung Digimax L730 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
My samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Jan 03, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 camera. Is fully charged. Power button is permanently on. Lens locked - can't move in or out. No display
take out the battery wait for a few sec and then put the battery back on, then switch the camera on.
for the lens try to gently force open or close the lens.
this works on my camera. i have the same problems. hope this helps.
Dec 03, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
229 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
