Question about Elite Sl 3000 Ul Sliding Gate Operator
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Posted on Jul 22, 2010
  • 3 Answers
Make sure timer isn't set to max of 60 seconds.
Posted on Aug 21, 2015
  • 28 Answers
how do you deactivated manually?
Posted on Jun 22, 2015
Lift gate open
Has anyone suggested replacing the BCM (body control module)
Dec 12, 2013 | 2008 Jeep Grand Cherokee
Gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Mar 05, 2013 | 2010 Jeep Liberty
Rear tail gate light stays on
I hope this is an easy fix, but I doubt it!
Try to locate the switch, it should be a push button, that opens when you lift the rear gate, and closes when you close the rear gate.
If that switch is broken, it will stay on.
Also, the switch, usually made of plastic, could have fallen down inside the hole where it mounts, also causing it to stay on.
Perhaps it need adjustment to turn off the light.
If the lift gate has been sprung or is not exactly where it was when new, you might be able to adjust it somehow to work.
Like if the gate does not come close enough, you might glue or screw a piece of metal on to the contact surface to make it turn off the light.
My sad suspicion is, put a piece of tape over the light!
That is what I have had to do in a few cases.
Be blessed.
Mar 01, 2013 | 1991 Toyota Previa
2004 grand caravan some dome lights stay on rest shut off normally
Is there perhaps a problem with the dome light switch on the lift gate? Close all the doors, open only the lift gate and find the switch on the lift gate frame (usually a rubber covered "bump") and press it in. You might have a loose wire shorting against the bodywork or the door is not depressing the switch properly.
Feb 27, 2013 | 2004 Dodge Caravan
Where is the gate open indecator switch located on 2010 dodge grand caravan
The switch in on the latch itself. When the striker goes into the latch it also trigger the small micro switch.
You can try something like WD40 and spray liberally into the latch and open close it 10 times or so to see if it frees it up.
Jan 23, 2013 | 2010 Dodge Grand Caravan
When I open my rear gate the done and interior lights stay on when the gate is closed. I have to pull the fuse. If I drive around and put the fuse back in the lights stay off till I open the gate again and...
Hello, it sounds likethe switch that controles the light is jaming, try pushing the sswith in and out firmly with your finger. If you get the same responce as you do when uou close the tail gate you have found the problem. The switch may need replacing.
Nov 05, 2009 | 2000 Jeep Grand Cherokee
The "Lift Gate Open" Light stays on, on the overhead message panel. The actually lift gate is closed securely.
The lift gate latch is at fault the switch contacts in the latch are worn out replace the liftgate latch and your problem is solved
Aug 29, 2009 | 2002 Jeep Grand Cherokee
Vehicle Entry Gate Will Not Open on Schedule.
after you program the door, you have to push "sel" and override the load until the next setpoint.
Apr 13, 2009 | Hardware & Accessories
Display console
There is a switch in the lift gate latch that closes when the gate is closed and turns off the light, this switch is defective, replace it and the light will go off.
Sep 16, 2008 | 2004 Jeep Grand Cherokee
Elite Sl 3000 Ul Sliding Gate Operator Logo
1,189 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
