When you start the washer to fill,the water doesn't squirt continuously into the machine,it squirts on and off for a couple of seconds,then covers the bottom of the agitator,stops and starts beeping,lights left on for short wash and long wash only. once turned off and turned on again set to spin but won't spin
  • 2 more comments
  • luisa_sgro Jul 09, 2010
    Hi just read your posting.Could you please supply the make and model number of the machine and I can help you further.
  • linda145 Jul 12, 2010
    Kelvinator Smartdrive 5.5 by Fisher & Paykel
  • linda145 Jul 13, 2010
    The lights that illuminate are 1 and 5 (from the left) Thanks!
  • linda145 Jul 15, 2010
    Hi
    The machine has been in storage for 6 months,we moved,gave it a thorough clean,did 2 loads no trouble then the next day had this problem,don't know if the spin was noisy.
  • Washing Mach... Master
  • 713 Answers
Hi Linda just read your posting.Sorry to ask you this but could you confirm the lights that are lit when it is beeping.On the wash progress row of lights, starting from the left to right which ones are on?Is it the 2nd and 4th or the 3rd and 7th ---etc----?Please reply with additional information and I can help you rectify this fault.
Posted on Jul 13, 2010
  • luisa_sgro Jul 15, 2010
    Hi just read your posting.Now the fault you have indicated is called MOTOR STALL , and this occurs most of the time because of faulty bearings and seals.The other 2 reasons for the fault are your motor or motor controller.Has your machine been noisy on spin?Please reply with this additional information and I can then guide you on how to rectify this problem.
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Windshield washer fluid doesn't squirt after filling the resevoir & resevoir is empty later.
Make sure your washer fluid line that goes from the tank to the pump is connected.
Jul 24, 2011 | Ford Taurus Cars & Trucks
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
Hi k2 series have alot of trouble does not always start on full pressure pull the trigger it just squirts a stright line of water out of the gun takes a while to get on full pressure if at all. many thanks...
HI This is caused either by a partially blocked nozzle on the end of your lance or the unloader valve sticking inside the machine. You can clean your nozzle by inserting a pin etc inside the end to clean it out. If this doesn,t work then it is most likely the unloader sticking. You need to remove the yellow cover and remove the unloader valve assembly.This is the bit that goes in and out when pressing the trigger. Remove this section then grease and oil the unloader and re fit. This should cure your problem.
Jun 10, 2010 | Karcher K2.26 Electric Power Washer
9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
Mar 14, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
thanks
joyce
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
Cannot get machine to disperse any water or solution
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just refasten it down.
Apr 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Saeco Magic squirts water out the wand when brewing
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Apr 11, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
