Question about Friedrich CP06C10 Wall/Window Air Conditioner
My Friedrich quietmaster stopped working.No power.Outlet working.
At 9pm, the unit just went quiet. No lights, no nuthin'. I flipped all the circuit brekers and then I tested power from outlet. It's live. 89 degrees ouside.
SOURCE: fan not working
some fan motors have a start capasitor, some have a run capasitor and some have both. if you take out the capasitors (normally in the junction box) take note of which wires go where and head to a refrigeration spare parts wholesalers they should be able to give you the right ones then replace them. this shouldnt cost any more than $20 if that doesnt work you will need to replace the motor.
Posted on Aug 07, 2007
  • 230 Answers
SOURCE: Friedrich QuietMaster SS12H10
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Posted on Jun 30, 2008
  • 744 Answers
SOURCE: REMOTE CONTROL
Start here:
http://www.friedrich.com/
Posted on Mar 28, 2009
manhandy
  • 146 Answers
SOURCE: The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Posted on Jul 15, 2009
heatman101
  • 43501 Answers
SOURCE: Friedrich QuietMaster SS08J10R Air Conditioner is not working
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
A NEED A POWER CORD FOR THIS UNIT
Electrical Characteristics (60 Hertz)
Volts Rated: 115
Cooling Amps: 12.0
Cooling Watts: 1,343
Heating Amps: N/A
Heating Watts: N/A
Circuit Rating - Breaker or TD Fuse: 125V - 15A
Plug Face(NEMA#): 5-15P
This unit is 115vac and 15amps draw.
Find a heavy cord. ACE or Home Depoet
May 01, 2014 | Friedrich QuietMaster KS15L10...
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
My quiet master is leaking water inside my store.How can I drain the water.
1. check the filter.2. remove the front cover and check the front coil behind the filter and check any drains that might be plugged. some units do not have drains and if not that is fine. 3 Be certian that the unit is tilted to the outside about 1 inch or so.. It should then drain as it is designed.. hope this helps let me know.. Jon
Aug 03, 2011 | Friedrich QuietMaster SL35J30 Air...
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Jun 30, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Friedrich CP06C10 Wall/Window Air Conditioner Logo
75 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
