I have a Fujitsu 18C1 split type AC system that does not power up at all. I replace the condenser unit fuse and the wall unit fuse, but the system continues to blow fuses on the wall unit only. What might be wrong with my system?
  • 760 Answers
When you say wall unit I assume you mean indoor portion that circulates the cool air or the evaporator. Check to see if the fan will turn freely when unit is off. This fan should spin free. You could have a bad fan motor a shorted capacitator. This unit should have some type of a drain line to drain condensate. Be sure this hasn't gotten plugged up causing a moisture problem inside the unit. You could "unwire" the motor and see if this stops blowing the fuses. If it does, then your problem is isolated to the fan motor.
Posted on Jul 09, 2010
  • 3 more comments
  • duggdeth Jul 10, 2010
    OK. Here's what I found:
    (1) both the outside condenser unit fan and indoor evaporator unit fan spin freely w/AC off
    (2) drain line is clear
    According to these results, can I assume it's a shorted capacitor? And if so, which capacitor is likely to be the problem?
  • duggdeth Jul 11, 2010
    Another update on troubleshooting: I pulled the control board (Edition 06) from the wall unit and found scorch marks on the back of the board @ R2. Areas on the backside around R1, D1, D2, and D5 also looked like the solder heated up around them, but no scorching is evident.
    All the capacitors look ok, but I haven't put anything on a meter yet. Does this new info give you any more clue as to the nature of my AC problem? Better yet, is it possible to just buy a new control board and filter board rather than replacing individual parts?
  • Tom W Jul 11, 2010
    I viewed your last posting about black marks, and possibly melterd solder. If these terminals are for the relay that turns the fan on, it coudb be thatevaporator fan motor (or it's start capacitor) is shorted. Again, I would disconnect the blower fan motor. If the unit powers up now witout tripping breaker or blowing fuse, it would indicate you have a motor problem.
  • duggdeth Jul 12, 2010
    I disconnected the blower fan motor, and no change--although it didn't blow the fuse now either. There appears to be no power getting to the inside wall unit @ all. I traced the yellow molex connector from the control board (marked CN4 FANCAPA) to what I believe is the fan start capacitor? (a black box, approximately 1&1/2"x 3/4"x1&1/4"). It also doesn't appear to be "bad", although I haven't run a meter on it. What else can I do to try an fix this POS?
  • duggdeth Jul 13, 2010
    More new findings: the fan motor capacitor tested fine--no short/open circuit. Any other ideas you might recommend?
Ac unit is dripping water
Find the drain hose outside the wall and attach a wet/dry shop vac and vacuum out the line......this clears blockages 95% of the time. :-)
May 22, 2010 | Fujitsu 18C1 Air Conditioner
Fujitsu asu18c1 mini split ah
change the fuse donot operate the unit and change the thyristor
Feb 23, 2009 | Fujitsu 18C1 Air Conditioner
Wall unit emits a chemical smell when the unit is running
check the condensate pan clean out with vinegar water solution make sure you do not see any oil residue that would be a sign of a refrigerant leak let me know if you have further problems your manual should tell you how to get the cover off
Jan 08, 2009 | Fujitsu 18C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
LEAKING SPLIT TYPE AC
drain line is more and likely stopped up
Dec 02, 2008 | Fujitsu 18C1 Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu ASU9RLQ
check indoor unit sirkit board
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
