Question about Ducane 30400042 (LP)
Only 1 burner lights
Ahh...1st burner lights fine, 2nd burner lights and then goes out, and 3rd, 4th, and 5th won't light at all...help!!
    Champion:
  • 274 Answers
This symptom is typical of a failing regulator. Try replacing the regulator and hose, easy to do and inexpensive.
Posted on Jul 12, 2010
What is the function of 1st,2nd,3rd,4th,5th gear?
the function of the gears are to transfer and convert energy created by the engine into momentum
Feb 12, 2010 | 2003 Toyota Corolla
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Transmission problem with a 1999 audi a4 quattr0 2.8l
you may not need a transmission replacement, just try replacing the sensor of the transmission, it may help
Jul 02, 2009 | 1999 Audi A4
What different gear box can fit honda integra xsi vtec 1600cc b16a? i want to change my gear box ,and i want to know what exactly other gear box can fit my car?thanks its a integra bot the product can show...
J1/S1 Found in: Integra XSI/RSI (DA6) Type: Cable 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400 Y1 Found in: CRX/Civic (optional LSD) Type: Cable 1st: 3.166 2nd: 2.052 3rd: 1.416 4th: 1.103 5th: 0.870 R: 3.000 FD: 4.266 YS1 Found in: Integra 92-93 XSI/RSI (DA6, DA9) Type: Cable 1st: 3.307 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.880 R: 3.000 FD: 4.400 S80 Found in: Integra Type R 98+ (LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.785 S80/Y80 Found in: JDM SiR-G (optional LSD) Type: Hydraulic 1st: 3.230 2nd: 1.900 3rd: 1.360 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.400 Y21/Y80/S80/S4C Found in: JDM 96-97 Integra R(LSD) JDM Civic R [EK9](LSD) JDM Civic SiR [EK4, EG6] JDM CR-X DEL SOL SIR (EG2)(optional LSD) USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400
Jun 08, 2009 | 1990 Honda CRX
Puzzle 100 in professor layton
This took me ages. Hope it not too hard to follow.
1st square is a small one made up of the top left four pins of the 1st and 2nd row,and is the only straight square on the board.
2nd square is made from 3rd pin top row connected to 5th pin 2nd row, then make a sq from here.
3rd square is made by connecting 4th pin top row to 3rd pin down on far right row, then make the largest sq from here.
4th square is made by connecting 5th pin top row to top pin in the far right row then make the sq from here.
5th square is made by connecting 3rd pin 2nd row to 2nd pin down far right row, then make the rest of the square from here.
6th square is made by connecting 3rd pin across on 3rd row to 4th pin across on 4th row, then make the rest of the square from here. Finally 7th square is made by connecting 1st pin 4th row to 1st pin 5th row, and make the rest of the square from here.
When I describe pins, I am talking about actual pins, not counting gaps where pin could be.
Hope this helps.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Ducane 30400042 (LP) Logo
141 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
