Question about Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 - all idnicator lamps blinking
All indicator lamps are blinking indicating high water level according to the manual.
ive cleaned the strainers and filters and tested the pump by bucketing in water which it pumps out OK but the lights continue to flash.
what to do next?
thanks
Patrick
  • 2 more comments
  • Anonymous Apr 28, 2008
    The same as the other user. The manual says that I can reach the outlet pump inside the machine by removing the coarse & fine stainers, the small cover in the bottom of hole and then rach the pump wing and remove eventual dirt. I am not sure what the pump wing is as the manual doesn't say. Any suggestions? I have tried using the sink suction pump to remove any airlock but this hasn't worked.
  • Anonymous May 05, 2008
    the disposal became clogged, and i believe during the process of discovering my clog i back washed water into the dishwasher activating the high water "overfill protection device" water will not enter the machine but the pump continues to run and all lights are blinking and F2 is showing on the panel indicating hight water . How do I reset this device? ASKO mod 1885
  • Anonymous Dec 14, 2008
    I had the same problem with my Asko 1585. Our old garbage disposal and the Asko stopped working the same day. I had already bought a new disposal, so went ahead and put it in, and it worked fine. But the Asko...
    MY SOLUTION:
    I then got my wet-dry shop-vac and made sure all the water was out that I could get. Turned on the Asko again and it appeared to be continuing a pre-running cycle, so I left it and went to bed. Next morning, I still had the solid line of flashing lights with the pump running ... problem not solved.
    It wasn't until a week later when I was pulling out the Asko to "look at it" that I remembered I had not removed the punch-out on the new disposal where the dishwasher connects to (it's there for those that do not hook up a dishwasher to the disposal). I removed it, put the entire setup back as it was, and am once again up and running as I should be.
  • saleivan Apr 18, 2009
    ASKO 1805 run without first running the Garbage DIsposal. Water level went high and leaked out the door seal and flooded kitch floor. Ran GD and machine pumps out but does not stop pumping and indicator lights continue to blink even with the door open...
    Problem Solver:
  • 5 Answers
Searched some more on this site and found the following from a guest (thanks). It solved my problem, the base where all the electrics and plumbing is located had a pool of water. I had to pull the unit out as I could not access this area from the front.
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
Posted on Apr 18, 2009
Whirlpool dp1040xtx flashing code 61 and 66. 61 flashed a couple times. What's wrong?
F6E1 - Water is not present in the machine when it should be.
Could be: inlet hose filter clogged, blocked holes on spray arms, dishes not loaded according to manual, water tap closed or water pressure too low, drain hose placed incorrectly, DW filters clogged, check dispenser (missing dispenser gasket, improper detergent), check water indicator (OWI or VWI) depending of model DW, check connections beetwen OWI (optical water indicator) and CB (control board), main motor, wiring, control board.
Check the foam level in the appliance. Depending what kind of detergent was used. Was the foam level too high?
Comment: Washing tabs combined with short washing cycles can produce too high foam level.
Dado
Jun 17, 2015 | Whirlpool Dishwashers
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
Dishwasher will not drain. F2 shows up on panel
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Aug 20, 2010 | Asko Dishwashers
All the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 DW Circulation pump NF. What is the most common cause / fix. Is it the motor, impeller, capassitor or control board?
The pump motor can easly be tested by 1) Physically looking at the pump motor in the pump out mode. The motor must spin freely. The motor has 2 push on electrical connections that must have AC voltage across them in pump out mode. If voltage is present and motor not spinning indicates the motor windings are open circuit. No voltage at the 2 terminals indicate that the electrical / electronic switch circuit is faulty. The impeller could be jammed from debris or pipe blocked.
Jan 25, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Fault indicator on Asko D-3250 (heavy wash/ too much water has en
the float switch must be stuck the up position or water inside the pan or a bad float switch..
hope it helps.... if NOT let me know more about your problem...
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Fault Indication - "Over Flow"
Does manual say to clear drain by running high temp water to clear drain; i dont think so. Now you have to unscrew the back to see where the leak comes from - by pouring plain water into the machine (where u put clothes). Unplug all electrical connections, ie disconnect the machine from the wall socket. Pl post back
Apr 18, 2007 | Asko W6761 Front Load Washer
Asko 24 in. 1805 Built-in Dishwasher Logo
603 people viewed this question
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
