Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
How do you manually set the convergence on a Sony KDF-60XS955
Our blue LCD panel is failing. We have a new Optical Block being delivered tomorrow and we need to know how to set the convergence on a Sony KDF-60XS955. We can't find the flash focus button. How do you manually set the convergence?
  • 201 Answers
Lcd projection sets don't need a flash focus ...there is no convergence alignment. replacing the optical block should be all you need to do. the block contains the lcd panels with the picture already aligned.
Posted on Jul 09, 2010
I have a large yellow spot on my screen..... Will changing the bulb fix this - or is there another remedy?
Your set uses red, blue, and green lcd panels to produce your colors. The lamp provides the illumination. What has happened is the blue lcd panel has been damaged in the area you are seeing the yellow. The fix for this is to have the optical block (also known as the engine) replaced. This is a very expensive part,... you may want to move on to a flat panel tv.
Aug 29, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots, marks, and a bluesh tint on the screen.
sound like you have a bad optical block which is a common problem for sony lcd projection sets
Jan 04, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue dots and streaks
Blue streaks might have been just your video connection and problem with signaling. But, blue dots is faulty light engine, aka "optical block". The engine in this could be a defective LCD array. Very expensive, a optical block is about $850. Hope it's still under warranty. You could get a rebuilt one, possibly. Need service adjustment too. Bad problem that Sony has with these kinds of sets.
Oct 05, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Oct 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega KDF-42WE6 55
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
437 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
