Question about Microsoft Xbox Console
X-box the screen comes up saying that the x-box needs maintenance and on the left top corner of the screen a code? comes up, it's 07. What do I need to do?
  • j_j13 Apr 19, 2008
    Thanks for your support and play HARD!
  • kraka_nts Apr 28, 2008
    have the same problem as above sometimes including a repetitive ticking noise
I have the same problem and prevents the system from working.
Posted on May 10, 2008
  • 4 Answers
O,O i never heard of that one!
i am looking for my xbox live code! x]
Posted on May 08, 2008
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Why am i getting blank copies from my printer
The chances are good that what U need to do is a printhead cleaning. On the printer if it has a LCD screen scroll through the menus and look for Maintenance or tools and then look for printhead cleaning . It can also be done through the software by going to the top left hand corner of the page U are trying to print and click on the button or File scroll down to print and click on that and that brings up a box with your printer name in it and beside that is a box called properties and look for maintenance or tools there. After the printhead cleaning it will ask if U want to print a test page - say yes if that page looks good -problem solved but it will probably take a few cleanings if U R getting blank pages now. Warning repeated cleanings use a lot of ink so only do what you need to. If after several cleanings U are still getting blank pages U might need to replace the printhead
Aug 03, 2014 | HP Business InkJet 2800 Printer
For got pin code
You will need to get into maintenance mode and "clear user data". Do this by touching the lower-left corner of the screen while turning on your Nuvi. Keep your finger in that corner until you are prompted to go into "Maintenance Mode". Choose "Yes" and once in the menu, choose "Clear User Data". After that, exit and reboot the unit. If the lower-left corner doesn't work, try each of the other three remaining corners until you get the right one.
Note: Any user-stored and configured data will be lost as the system is restored back into factory mode. However, it should be noted that this will not affect any upgraded map files.
Jan 25, 2011 | Garmin Nuvi 370 Car GPS Receiver
I have an xbox the first one black with x on top it has just started to come up on the screen in a box saying your xbox need service can you help thanks
In the top left or right corner there will a number, eg 07, which means its a hard drive error which means the xbox is more or less stuffed as each hard drive for the original xbox is specific to the main printed circuit board.
Theres another symtom that tech's call FRAG lights. Where the lights Flash Red And Green, hence the acronym FRAG, if you are getting this symptom, theres a chance your xbox has died.
I hope this helps. Good luck.
Sep 06, 2010 | Video Game Consoles & Games
A black box in the top left corner of the screen
Make sure that the PIP (Picture in picture) function is disabled.
Nov 04, 2009 | Philips 50PFP5332D 50 in. Plasma...
Superbox problems ...screen keeps saying that data is being updated...and screen remains blank!! Help!
unplug the box and when you plug it back in press menu and then key in 1570 and when the other menu comes up press nagravsion and then key in codes 00-- b0 b8 4f 04 e6 5f 87 80
01--a3 eb ec 07 d6 49 d2 eb
This worked today for me, many thanks
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Our x box will not play games .. it comes on appears to be getting ready then says there is an error..your x xbox requires service ..please call x box customer support...There is the number 07 in the upper...
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. Also try to reconnect the ide cable to the motherboard.
There are 6 star drive screws on the bottom of the Xbox. Four under the rubber pads and 2 more under the stickers. If you remove these, the top should come off. Make sure all of the cables are tight (unplug it first!).
If this doesn't work, there are ways to fix it, but it involves building a computer chip with parts from Radio Shack and soldering wires into the Xbox in order to get a 'code' that allows you to replace the hard drive. The good thing is that used Xboxes are getting pretty cheap, I've seen them as low as $50.
If you really want to try building the chip, start here:
http://forums.afterdawn.com/thread_view.cfm/357863
Jul 10, 2008 | Video Game Consoles & Games
Star view box
DID YOU TURN ON YOUR EMU? AS THAT NEEDS TO BE ON FOR ALL CHANNELS TO WORK
Jun 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
