Question about Watches
Hermle 340-020 clock euns ok chimes woking,will not strike hours all wheels,pinions and mainspring are in gooo=d shape. I havw 20 years clock repair experience but problem is above my skill level
    President:
  • 1,561 Answers
You need access to the front of the clock movement. You will either need to remove the movement from the case or at least take the hands and face off of the clock.
There is a lifter that is pushed upward by a four pronged cam on the minute hand shaft. As you look at the front of the movement move the minute hand clockwise, you will see the lifter moving upward and dropping every quarter.
The cam on the minute hand shaft has 4 prongs, one is higher than the other three. The high spot is for the top of the hour. The lower 3 prongs should lift the lever high enough to actuate the first 3 quarters, the higher one is the only one that should actuate the top of the hour. Your lower three prongs are not lifting high enough to make the clock chime the first three quarters.
The lifter is sort of V shaped, to make them lift higher you would put a pair of needle nose pliers between the V and spread them out a little bit. When this piece is adjusted correctly the clock should actuate the first 3 quarters only but not the top of the hour. The top of the hour should only be actuated by the higher prong.
Take care.
Posted on Jul 09, 2010
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
It's a 3 key chime and strike clock that chimes every 15 min and strikes hours. for last one month it doesn't chime at 12, 3, 6, and 9 position and the hour strike is not synchronous with min hand
More than likely, there are springs that activate the levers for it to chime, or bong, they may have got jammed up, you can open it up, and see if you see anything like that, if not, you will have to take it to your local jewelry store, or watch/clock makers to have them take a look. You never indicated what type of clock (make or model) so I can\'t be certain. Maybe a ships clock? They may want to charge you for a overhaul of the movement, but you can tell them to just "make it work" if it was running fine before (keeping time well) then an overhaul probably isn\'t necessary. It sounds like something may have got jammed.
I hope this helps !
Nov 16, 2013 | Watches
How to adjust a Hermle grandfather clock?
you can try this although it may not work with your movement: set the clock at 9 and then move the hands forward past the 12 position. count the strikes. move the hands backward to the 9 position and then advance forward to the 12 position. count the strikes. did the strikes increase by one? if so, keep doing the same thing until your get 12 strikes when you are on the 12. then you can move forward and set the correct time and have the correct # of strikes.
Jul 25, 2013 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
    I suspect that the mechanism needs cleaning.
    Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
    May 01, 2010 | Watches
    I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
    With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
    Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
    Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
    Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
    Hope this tip guides you to a solution for your clock.
    r/ David
    http://antiqueclock.clockstop.com/
    Apr 06, 2010 | Watches
    My new wall clock chimes 2 minutes BEFORE the
    You will need to do a mechanical adjustment to the hand.
    Loosen the hand nut and adjust the hand the tighten.
    Hope this tip helps to solve your problems
    R/
    David
    Mar 19, 2010 | Watches
    I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
    Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
    Feb 02, 2010 | Watches
    Believe chime springs have been over wound
    The idea of "overwinding" is probably the most common myth in clockmaking. A clock cannot be wound too tight, unless it is wound so hard that the mainspring breaks, in which case the spring becomes completely unwound and will not wind up again. What has actually happened is that the clock is fully wound, but does not unwind because it is not running for some other reason. Letting down the mainspring would have no benefit.
    You're correct that the clock was made in 1974. This is far beyond the expected lifespan of the clock. It is possible that lubrication by a qualified clock repairer could get the clock running again, but considering its age, it may be more likely that the movement is worn out, dirty or corroded and needs replacement.
    The three keys should be wound all the way, as far as they will go, once a week. This clock should be self-starting when wound, so the fact that it has been sitting wound without running for years indicates a previous problem that prevented the clock from starting and running the mainspring down on its own.
    Nov 04, 2008 | Watches
    Watches Logo
    208 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
