Question about Sony Handycam DCR-SR200 Camcorder
Lcd screen is blank...ribbon cable problem? - Sony Handycam DCR-SR200 Camcorder
This is the cheapest replacement ribbon cable I have come across: http://www.tmart.com/LCD-Flex-Cable-for-Sony-FP610-DCRSR200-SR300_p111909.html
Posted on Sep 28, 2011
  • 26 Answers
Turn the display around and see if it will be ok sometimes ,if so ,it 's alwasy the lcd ribbon cable broken ,you can get the replacement cable easily as following if you wana replace it yourself :
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170492161851&ssPageName=STRK:MESELX:IT
Posted on Jul 20, 2010
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: Hello, My Sony DCR HC19e LCD
It is highly possible that the flexible connecting strip ribbon has torn or damaged which is a normal fault with these models. So to remove and connect the ribbon you will need to open the camcorder side panels, need to take off the screws on the sides to take it apart, next take the display unit off and the ribbon will be visible passing through the pivot. check this to confirm , get the replacement from SONY , remove the connection from connector and replace.
You can connect the camcorder using the video/audio cord to the TV and see the functions on screen thereby accessing menu.
Posted on Apr 15, 2011
Blank screen
Is this lap top? If you just have the screen glowing without any pictures, you need to check the ribbon cable at the LCD panel T-CON bd.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Hopefully it did not blow the fuse on the T-CON bd.
Jun 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
NO DISPLAY
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Nov 07, 2009 | Nokia N70 Cellular Phone
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Display problem
try reformatting it.
May 05, 2009 | Sony Ericsson K750
Blank screen
You can open the camera and check to see if the LCD ribbon cable is still connected to the main board. If it was dropped they can become dislodged. There are two cables the smaller one is the most sensitive to coming loose. When disconnecting and reconnecting the ribbon cables, make sure you are careful while lifting the tabs that hold the ribbon cables in place they are hinged and will lift up and the ribbon cable will slide out. Note the large ribbon cable feeds through the camera to the front main board. Hope this helps
Apr 19, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
My sidekick went blank i missed my phone not working the right way
there is problem with ribbon of phone. take it to techncian so it can be replaced with new one. after replacing everything will start working
Feb 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Balnk white screeen on my A610 powershot
unfortunately since the problem is on the hardware (lcd screen), there is no way of fixing it except from the people of the service center.
Jan 14, 2008 | Canon PowerShot A530 Digital Camera
No display on lcd screen
Hai First check other functions, If all the functions ok then LCD ribbon cable may be defective, replace LCD ribbon cable. best of luck udupi Prathiksha Electronics Bangalore
Mar 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam  DCR-SR200 Camcorder Logo
844 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
