Question about HP Pavilion dv6000z Notebook
My hp pavillion dv7600 is not charging. The power supply is plugged in, it starts off like the battery is charging for approximately 15sec. then it stops. the laptop is approximately 1.5 years.
  • HP Master
  • 1,606 Answers
Time to replace the battery. 1.5 to about 2 years is typical life for most laptop batteries. You can extend that but most people typically don't get more than 2 years.
You should do a search for the battery online as you can save a ton by shopping around. For example I have a Toshiba laptop I need a new battery and was shopping around. From Toshiba the battery is $202 from several other places it was $35 and up with a 3 year warranty. The cheapest place was AMAZO...com something sounded like that river in south america you know the Amazon. Not that I'm recommending anyplace. You can find local places that may be close to that price so that can save on shipping.
Posted on Jul 09, 2010
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
My hp pavillion dv4-1220us laptop, won't start up...I press the power button and it turns on for a couple seconds and then turns back off....
1) Is it the battery, power up using the power supply.
2) When the power supply is plugged in, is there a charge light/led (could by a bad power supply not charging or providing a good connection)
3) Is the CPU over heating? Check the vents underneath are they clogged with dust?
After this, you're getting into internal faulty component issues and need someone to look at it.
Apr 13, 2010 | HP NB199UA Pavilion Notebook
HP Pavillion DV6700 is shittung down
This could be numerous things. It could be an over heating problem, a virus, a power supply failing or something wrong in the power adapter on the motherboard where the power plug plugs into the laptop. If you plug in the laptop and see the battery charge light come on then the problem is most likely an overheating problem or a virus. If the battery charge light comes on then I would recommend taking it to a reputable repair facility to have them diagnose the problem.
Jan 01, 2010 | Computers & Internet
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
Dec 29, 2009 | HP Pavilion dv6000z Notebook
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
My red xbox 360 controller wont charge with the included play and charge kit after i turn off my console, it works if i do it as soon as it dies but not if ive played for a little while and then turn it...
Basically an xbox battery has a built in 'memory' that it tells the xbox how much charge is in it and the problem with rechargable batteries is that if they're not used for a while and left at room temperature their charge begins to dissipate so when you plug it in the battery 'thinks' it's charged and tells the xbox the same when in truth it's not. What to do is keep plugging and unplugging the charger on top (waiting until the light comes on) until the charger light stays red (as opposed to going red then immediately green) the small amounts of charge put in each time will eventually give the battery enough juice to clue it as to just how much power it REALLY has in and will then start charging as normal.
Apr 25, 2009 | Microsoft Xbox 360 Controller
Hp pavillion dv7 won't power on
Same issue - solved by disconencting everything (main battery, CMOS battery, RAM, hard disk and wireless card). Held in power button for 20 seconds (HP say this removes any electostatic charge on the main board). Reconnected everything and machine booted to Windows. Ran HP's onboard diagnostics and everything checked out OK.
Mar 30, 2009 | Computers & Internet
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
474 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
