Question about Isomac Millenium Espresso Machine
I have an isomac millenium, 3 years old and the pressure gauge has dropped to 0 and subsequently the steamer won't work. Any ideas how to fix?
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Isomac Rituale over pressure
Check if the pressure relief valve is working fine, if not you need to replace the valve.
If valve is fine check if there is an obstruction in the lines, this can incrtease the pressure.
If everything else is ok, replace the pump.
Posted on Sep 08, 2008
  • 1089 Answers
SOURCE: how do I remove the shower and the diffuser on an
Hi
You need to remove the brew head gasket in order to get the screen out. Then you will see everything else. The brew head gasket holds everything in.
Posted on Jan 16, 2011
Sep 08, 2008 | Isomac Rituale Espresso Machine
Oil prresure indicator drops to 0 when vehicule stop
Most likely a bad sensor. If you had 0 pressure you would know by vehicle reaction. Get an oil pressure gauge and remove sensor and install gauge. What is actual pressure? Bad sensor? Always a good idea to do internal clean, cheapest is SEAFOAM
Aug 15, 2013 | 2003 GMC Envoy
How do I remove the shower and the diffuser on an isomac millenium?
Hi
Jan 16, 2011 | Isomac Millenium Espresso Machine
Leak around filter
Any leaks aroung the portafilter is usually the brew head gasket. You just need to replace the gasket. The gaskets only last about 1 year so if yours is older that that, it needs to be replaced.
Dec 07, 2010 | Isomac Millenium Espresso Machine
I have an isomac millenium which stops working after being warmed up for more than 15 minutes. It would have to cool down completely before I could turn it on and get the green light to turn on again....
HI
There are a few things that will cause this.
Your SSR (solid state relay) is bad. Its on the bottom of the machine inside. If you can see a green light on it , its probably OK.
You could have a thermal fuse on the side of the boiler by the heating element that is bad.
You have checked that your water tank switch is working. Push down on the water tanks to see if your lights come on.
Your heating element is bad.
Your Computer is bad.
Nov 09, 2009 | Isomac Millenium Espresso Machine
Isomac expresso machine
We have owned an Isomac Millenium for ~2y.
In the first months, we encountered low water to the brew head, although both the steam and hot water wands had decent pressure and flows.
Adjusting our grind, so that the coffee beans were coarser helped immensely--for awhile.
Then the problem gradually reappeared as an extremely slow brew time. Our machine was still relatively new, so we shipped it back to our place of purchase. It came back working just great and interestingly the filter in the resovoir was now filled with the filtering particulate it did not come with.
I am surmising, that however great the engineering is on the Isomac, manufacturing leaves something to be desired. Do not let your warranty expire. Pay the shipping and fix your otherwise great machine.
Nov 05, 2007 | Isomac Millenium Espresso Machine
Isomac Millenium Espresso Machine Logo
81 people viewed this question
Top Isomac Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Isomac Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
