Question about Haier Refrigerators
Haier refrigerator PBFS21EDAS temperature read out for fridge and freezer do not stay on ...the selected number..come on blink then two short lines appear. the whole system turned off when the quick freeze ice maker was selected...power was turned on again but then situation as above...it is not doing any cooling PLEASE HELP..AL
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
  • 150 Answers
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
Posted on May 08, 2008
SOURCE: No display panel indications on Fridge freezer
We had the same problem due to a power surge- we pressed the power cool and power freeze buttons at the same time until it reset and it's fine now. Hope this helps!
Posted on Sep 26, 2008
  • 358 Answers
SOURCE: Haier mini fridge thermostat confusion (which is cold)
Max means colder.
Posted on Sep 02, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: WHERE IS THE TEMPERATURE CONTROL
Sorry to read about your problem, I hope this helps you out.
the freezer adjustment, is in the refrigerator at the top
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 05, 2011
My haier fridge freezer is making a loud buzzing noise. Any ideas what it is and can it be repaired
Depends what type of buzzing it is?
It may be an alarm telling you something.
It may be a mechanical buzzing from a motor, relay or solenoid.
Check your manual so see if it has alarms.
Google
make model manual
or visit the Haier website
Some do have an over temperature alarm like this one, so check that the freezer door is properly closed and not impeded by frost build up.
Fridge Freezer
Jul 04, 2016 | Haier Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
Jun 29, 2013 | Samsung RB217ABPN Bottom Freezer...
The temperature for the fridge and freezer will not stay constant. Why?
I would think first of the defrost termination thermostat malfunctioning.
This would vary the defrost time since it regulates the defrost time by temperature.
This is the most common failure in fridges next to start relays.
It is a two wire item in the freezer section which is clipped onto a tube. It senses
line temperature and turns off the defrost element when that temp is reached.
Should be located in the freezer section behind the back panel. Model and serial
number should be inside the refrigerator compartment, Part should be available
at an appliance parts store. Hope this helps.
Jul 18, 2011 | Kenmore Side by Side Refrigerator
WHERE IS THE TEMPERATURE CONTROL FOR THE HAIER........AND HOW DO YOU REGULATE THE TEMPERATURE. I PLUGGED THE HAIER IN AT 7 PM ON 1-4-11 AND CHECKED THE TEMPERATURE AT 8 AM 1-5-11 AND IT WAS 24...
3 Thumbs - Helpful
Jan 05, 2011 | Haier HTE18WAA Top Freezer Refrigerator
WESTPOINT upright freezer...alarm light blinking
Sir,
I need to know how to adjust WESTPOINT UPRIGHT FREEZER WVR-300W temperature? There is alarm light blinking every time and the temperature is not changing from 4c!!!! Thats mean, the freezer
Sep 29, 2010 | Haier HSE12WNA Top Freezer Refrigerator
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Refrigerators Logo
44 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
