Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet 50 inch zero turn pto switch will not engage the blades.
3 Suggested Answers
  • 601 Answers
SOURCE: I HAVE A CUB CADET 50 INCH CUT ZERO TURN, WHEN YOU
Most likely a short. You have to look in the area where engage switch gets blades going. You will find a cut wire or wires that are touching metal. This will kill a battery very quick. Fix wire , tie up wire so this doesn't happen again, and off you go. GOOD LUCK.
Posted on Jun 16, 2011
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
I have a cub cadet zero turn 50' mower, when the PTO is engaged both outside blades turn but the center one does not. What could be the problem
the spindle has broken in half inside the spindel take it in and have them to replace it it has press on bearing so they will have to do it
Jun 30, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Zero force 50 Cub Cadet runs fine , but when the mower deck switch is pulled , blades do not turn, does not engage
This would be one of a few different things, first check to make sure the belt is on properly and hasnt came off any pulleys, next check the clutch relay and fuse, next check the pto switch, and if all those check out, check the clutch for engagement, if it tries to engage with pto switch, then it may just need adjusted, if it doesn't try to engage, the clutch will need replaced, but check the other possible causes first.
Oct 14, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Blade engagement
PTO issue the blade should engage even if your not moving
Jun 21, 2013 | Cub Cadet 50 in. 23 HP Kawasaki Twin...
I HAVE A CUB CADET 50 INCH CUT ZERO TURN, WHEN YOU PULL THE PTO SWITCH TO ENGAGE THE BLADES THE BATTERY WILL DISCHARGE.
Jun 16, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Pto knob stopped working to engage blade. Is there a quick fix for this?
No fix is really quick. The switch may have gone bad or the electric PTO has stopped working. One fix is cheap,the switch, and the other is expensive, the electric PTO. Or you may have a safety switch gone out.
Good Day.
Oct 09, 2009 | Oregon Scientific Oregon Gator Mulcher...
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,694 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
