Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking out water underneath on spin - Whirlpool Duet GHW9150P Front Load Washer
    Champion:
  • 274 Answers
It sounds like hose that connects to drain pump has a leak,undo the back and look under drum you well see a small pump use a flash light,and try to see were the wate is comming from,now the edges are very sharp so were gloves,to remove the hose from drum to pump use a pair of visegrips,the hose is ribbed,make sure its unplugged.Yoy may want to try elec-tape for tempory fix .good luck
Posted on Jul 09, 2010
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
I have a 1995 Chevty Tahoe 8 cyl gas engine. It has a coolant leak and not coming from water pump, The pump area is dry. The (2) main hoses are not leaking either. The leak appears to be coming from...
it sounds bad head gasket if the pump is not leaking and the hoses are not then that may be the only thing left ...the fan you have on there is a clutch fan they kick in when your truck gets to hot ...they are supposed to spin free
Dec 24, 2010 | 1995 Chevrolet Tahoe
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
