Question about Acer Aspire 4720 Notebook
Turn on problem
When i want to turn on my laptop ,I face problem.My laptop starts and switched off after 2 seconds.It won't start.
My laptop's battery is 3 yrs old.
What can i do?
    Master:
  • 515 Answers
Does it work with the power cord connected? If so, you can try to update the BIOS. You can download the file to do that from the manufacturer's web site. Hope that helps.
Posted on Jul 09, 2010
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
2005 ford 500, won't start a lock light is
need to reprogram ignition key security system when battery disconnected. turn ignition key to the on position for 3 to 10 seconds until the lock light goes out then start vechicle.if lock light dont turn off turn ignition switch to on position 30 seconds until lock light turn off.
Jun 12, 2013 | Cars & Trucks
2008 escape hybrid won't start when you turn the
I am not familiar with hybrids, but i think when you start, it's starting with the battery, so I think you have a bad connection, check and clean the battery terminals.
Mar 25, 2013 | Cars & Trucks
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Screen won't come on when laptop powers on
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
Toll Free: 877 407 9229
any doubts you can get in touch with the best pc doctor through
www.thebestpcdoctor.com
Oct 01, 2011 | Compaq Presario CQ60-220US PC Laptop
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
1998 Ford Windstar Minivan: 1. I sometimes get an extended crank when trying to start engine after I've made a short trip. 2. My interior lights won't go out after I turn the engine off, so I...
YOU MAY HAVE A BAD DOOR AJAR SWITCH. HOWEVER, YO HAVE A TIMER THAT SHUTS OFF THE INTERIOR LIGHTS AFTER 300 MINUTES. IT'S CALLED A BATTERY SAVER FEATURE. TEST IT OUT.
THE EXTENDED CRANK MAY BE A CHECK VALVE IN THE FUEL PUMP IN THE TANK, ALLOWING PRESSURE TO DROP WHEN YOU TURN THE ENGINE OFF.
OR A BAD FUEL PRESSURE REGULATOR ON THE ENGIEN FUEL RAIL.
TRY THIS TEST, TURN KEY TO "ON" POSITION, WAIT 5 SECONDS, SHUT OFF KEY FOR 30 SECONDS. TURN KEY ON, WAIT 5 SECONDS, THEN START ENGINE. IF IT STARTS RIGHT UP, YOU ARE LOSING FUEL PRESSURE WITH ENGINE OFF.
THIS BUILDS UP PRESSURE IF IT DROPPED DURING SHUT DOWN.
REPORT TEST RESULTS.
PLEAE RATE, THANKS
May 16, 2011 | 1998 Ford Windstar
Dell D610 has started all of sudden switch off its self, after replacing bottom casing. But its starts normally after switch it on after 2 to 3 seconds
Take the battery out of the computer.. Unplug the laptop out of power source... Press and hold the turn on key for a while... Then put the battery back in place.. Put the adaptor back.. try to turn on.. If still not fixed. its a hardware failure...Contact Dell 18006249896 or a local technician
Dec 21, 2010 | Dell Latitude D610 Notebook
Acer Aspire 4720 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
