Question about Polaroid Televison & Video
Sir: I have a Polaroid TV Model 1513-TDXB. The included instructions are too sketchy. I am unable to operate the remote to be able to control the DVD player. Page 3 Press input has no reaction. When pressing input on side it displays but unable to scroll. I put in new batteries just in case. S.Wessling
Sir,
I reread and reactivated the inadequately written instructions and was able to overcome
the deficiency.
I am not stupid. I operate other electronic devices the have adequate instructions included.
S. Wessling
Posted on Apr 19, 2008
We have a Polaroid 15 inch LCD television with a built-in dvd player. It also allows for jumpdrive connection. I must be missing something but we cannot figure out how to play a dvd. I put a dvd...
Do you have the Polaroid 1513-TDXB? I assume you have tried the eject button on the side of the TV (the lowest button next to the DVD slot). There are a few things that can cause a DVD to jam and not be recognized by the drive: put in the disc label side to the back of the TV, home disc with a glued on label (if the label comes loose), two discs in the slot or non-standard optical discs.
Some slot optical drives have a manual eject hole on one side of the slot; it should be near the top of the slot on this unit. Straighten a paperclip and try pushing on the release mechanism inside that hole. (A small paperclip is the correct size.) Sometimes pushing the optical disc with a second optical disc will bump it loose (be careful you do not want the disc to be dragged into the drive). Another possible solution is to pry the disc up off the spindle with a credit card. (Note: trying this could damage the disc and the drive.) A similar card with double sided sticky tape can sometimes lift the disc off the spindle. Stick the tape on the card, then peel the paper off the other side of the tape. Insert the card to be on the top of the disc (sticky side towards the back of the TV) and press it down on the disc. Lift up slightly and pull the card and optical disc out.
If the disc has partially ejected, two credit cards (one above and one below) can grab it. Turning the TV on its side so that the optical drive is pointing to the ground can also work.
There are a few things to check once you get the disc out. Were there scratches or other problems that would keep the drive from seeing the disc? Other optical drive issues are dirt on the lens and the tracking unit failing on the drive. Blowing the dirt out of the drive may help. Otherwise, it needs to be fixed or replaced which means getting it out of the TV.
The manual for the TV is available at this review site: http://www.hdtvreview.com/Polaroid-1513-TDXB-hdtv.html . The direct link to the manual is http://www.hdtvreview.com/pdf/polaroid-1513-tdxb-manual.pdf .
I hope this helps.
Jun 09, 2011 | Televison & Video
Need a power supply for my polaroid lcd tv model 1913-TDXB
Hello
You need to contact nearest Polaroid Service Center to replace the power supply or contact the Product Support Here
http://store.polaroid.com/support_detail?p=4116
Good Luck
Jan 03, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
I have a Polaroid 1913 TDXB with the original remote just a few days ago it stopped working it has fresh batteries. I assume the remote has reset it's self is there a code for it?
Take the remote aparts,clean it with a Q tip with some rubbing alcahol.Clean the rubbers films and the circuits board.Clean IR in the tv and the remote.After this still don't work ur remote it dead,by the main CPU,it junk know.Here a website to buy a new one 1-800-Remotes Factory original.Never have need codes for oiginal remotes.
Nov 03, 2009 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Remote codes
what you need to do is call direct tv support they should have a code for you
May 15, 2009 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Need instruction to set up remote control to an Orion t.v.
Sir,
Provide me the details for easy to find. brand name and model no. of your tv and remote
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 27, 2009 | HP Font Set Bar Codes & More (36596B#C06)...
I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Mar 17, 2009 | Televison & Video
Polaroid tv codes
Hi, try this site out, pick the comcast universal remote that matches the one you have (from the pictures provided) and type in the type of tv, yours being a Polaroid, then your model information ( FXX 321C) , there are instructions provided on the site when you get to that point, good luck
http://www.urcsupport.com/index.php?mso_id=65
Jan 12, 2009 | Polaroid 1720-7 Remote Control
Code for polaroid tv
I just got a new directv receiver...dvr....the codes for polaroid were not listed on the unit but were included in the booklet that came with it. They are as follows....10765,10865,11262,11276,11314,11316,
11326,11327,11328,11341,11498,11523,11991,11992
These were all listed for Polaroid. Hope this helps.
Oct 18, 2007 | Polaroid 1720-7 Remote Control
Televison & Video Logo
252 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
