Question about Radio Communications
Dont know how to program the regency r804 scanner!Can you help me?
5 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: How to program regency model 1070 scanner?
I couldn't locate a manual for you, but this vintage 10-channel unit is fairly simple to operate.
Start by turning the unit on with the POWER button.
Push the MANUAL button.
Push MANUAL until you see the Channel you want to enter the frequency in -i.e: Ch 1, Ch 2, etc.
Enter the frequency with all the digits needed - i.e: 44.94 / 44.98 / 154.965 / 155.610 etc
Push the ENTER button. The frequency will now be in the Channel "Ch" you chose.
While still in the manual mode - go the the channel you expect to listen to most - then push "DELAY/HOLD". This will hold the scan so you will get the reply from the dispatch unit to the receiving unit.You can set this feature on any or all of the ten channels.
Push the "LOCK" button to lock out channels you no longer want to listen to, or that you want to ignore temporarily.
Posted on Dec 09, 2009
SOURCE: programing scanner
reset bc860xl
Posted on Jul 17, 2008
  • 74 Answers
SOURCE: how to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Posted on Oct 11, 2008
SOURCE: need schematic for Regency z30 police scanner
Make sure you lock the memory switrch in back to on this should slove your problem Good Luck
Posted on Nov 10, 2009
Does a Regency Toutch K 100 20 channels S1&S2 Does it scan all 20 ch at the same time, S1- ch 1 S2 ch 11- 12 Etc??, what is a d code mean?
Your Regency scans (samples) the programmed frequencies at the rate of approximately 15 channels per second, so it is constantly checking for an active frequency. "D-code" code refer to any of a number of things. Do you have the term in context?
Nov 20, 2009 | Radio Shack Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Need schematic for Regency z30 police scanner
Sep 28, 2009 | Radio Communications
I dont no how to program my regency z30 scanner
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you wish to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Apr 07, 2009 | Office Equipment & Supplies
Regency 1099 Scanner
Fr Err usually means that the freq entered into a certain channel is too high or too low for the band of the scanner. Also could mean that the freq's have been lost out of the memory. Maybe a dead memory battery, or been unhooked from the wall too long and lost it's charge. Been a loong time since I've seen one of those models,,, Let me know if it helps,,, Mechanic
Nov 04, 2008 | Radio Communications
How to program an old regency 1060 scanner
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Regency Touch K500
Yes, go to http://www.radiopics.com/1.%20Manuals/Regency/Regency_Touch%20K500%20(Manual).pdf
You can download the pdf format from that website, however you must have Adobe Acrobat Reader.
Hope this Helps!
Aug 23, 2008 | Radio Communications
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
85 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
