Question about Ford 8N Tractor
Having a problem with the lower links drifting down on the three point hitch. Impliment will stay where positioned when the tractor is running but when the engine is shut off the linkage drifts down. I have checked the flow control valve and it lowers drifts down at the same rate whether the control is turned to slow or quick. This is a 1981 Ford 1500 utility tractor. Two cyinder diesel and 4x4. Steve Diepenbrock
  • sdiepenbrock Jul 09, 2010
    I will follow your suggestion and let you know how it worked out.
    Steve
  • sdiepenbrock Jul 12, 2010
    I found the problem. Inside the rear hydraulic case there is a liner which a piston slides into and is adjusted by a valve, below the seat, for the lower links to go down slow or quicker. The piston has an oil seal on it. The seal on my tractor had become deteriated to the point that a quarter of it was missing. When the tractor was running the pump produced enough pressure or flow to keep the implement raised but when the engine was shut off the oil passed through the oil ring and the impliment was able to lower one its own. The fix was to install a new oil ring.
    I hope this helps you for further reference.
    Sincerely,
    Steve Diepenbrock
    Genius:
  • 1,016 Answers
Hi Steve,
You need to remove the relief valve attached to the side of the valve control block an check/replace any orings that may have failed.
Whe you reassemble ensure you remove all relief valve pressure and then using a pressurre gauge readjust the relife setting which will be between 125 - 205 psi
Hope this helps,let me know if you need more information.
Thanks
Jason.
Posted on Jul 09, 2010
    Thanks I will give it a try.
    Steve
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
How to adjust mahindra 5005 three point hitch down pressure?
1 Draft sensing lever in wrong position
Move lever to "light" position.
2 Rate-of-drop too slow
Adjust rate-of-drop valve.
3 Center link on upper front hole
Move center link to lower hole.
4 Draft control out of adjustment
Refer to service manual for adjustment procedure.
5 Internal mechanical interference with load control linkage
Refer to service manual to find interference, or possibly linkage coming apart.
6 Load control shaft or tube broken or bent
Replace load control shaft or tube. Refer to service manual.
7 Load sensing pin malfunctioning, or bad connections - only applies to newer tractors
Replace load sensing pin, repair faulty connections. Refer to service manual.
Aug 13, 2014 | Garden
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
Ford 8N Tractor Logo
105 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
