Question about Mitsubishi WS-55809 55" Rear Projection Television
Tv wont turn on green light just flashes continuously no power at all satellite box and dvd r fine what up?
  • Mitsubishi Master
  • 8,617 Answers
The caps on the DM board have failed. Very common problem. The repair kit called the WS55909 DM repair kit is the correct one for your model. Its available from www.tvrepairworld.com and contains the caps and the CD with instructions.
Posted on Jul 09, 2010
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
My technika lcd40-920 tv wont turn on standby flashing blue to red i held power in 30secs n stopped flashing but still wont turn on why some one said its trying to update but not sure can u help
How long have you had this TV? If it is under 12 months, get it fixed under the guarantee. If you have an extended warranty, use that to get it fixed.
I would suggest that you switch everything off, remove all the cable from your satellite box or games console and everything else, then switch off at the mains and unplug the set.
Now press and hold the power button on the TV for 30 seconds.
Now plug the TV into the mains again and use the TV button to switch on the set. If the lights continue to flash, then it's a repair job. If the lights are steady but there's no picture, then switch it off using the TV button and reconnect the aerial cable first and try it again.
Once you get a picture displayed, you can begin to reinstall all of the other cables until everything is working again.
Apr 13, 2015 | Televison & Video
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
My LG TV KEEP CLICKING AND WONT TURN ON
Normally there are some capacitors in the power supply area of the circuit board that will be swelled up, on the tops of the capacitors they will be bulged out. it is a common problem. should work fine after replacing these capacitors.
hope this helps.
Feb 16, 2012 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | Televison & Video
Hughes box wont power on.
Sorry it took so long to reply to your request for help.This Direct TV box has had a component failure. You will need to call Direct TV and have them replace the box. You can call Direct TV Customer Support at this telephone number 1-888-667-7463. Tell them that you are having a problem with Direct TV box and need a replacement. I hope this information help you solve your problem with the Direct TV box failure. Thank you for using FixYa and have a nice day!
Oct 21, 2008 | RCA DIRECTV Satellite Remote Control
Mitsubishi WS-55809 55" Rear Projection Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
