Question about HP Compaq WF1907 Monitor
No sound at all..
Hi there ..every time i try to go in to itunes .it pops up with "itunes has detected a problem with your audio configuration.audio/video playback may not operate properly".... iv tryed nearly every thing to fix it ...any solutions please..
    Master:
  • 515 Answers
I found several things to check about this issue.
First of all, make sure Windows Audio and Windows Management Instrumentation Services are running. Steps:
  1. Go to start -> run. If your keyboard has a ‘windows key’, which looks like the windows icon and is often located next to ctrl/alt, you can get away with pressing (and holding) this key, and tapping the ‘r’ key. I use this shortcut almost every day. On that note, windows-key+e I use even more- try it.
  2. type ’services.msc’, without the single quotes. This opens a list of the various services running on your computer.
  3. Make sure iTunes is closed.
  4. Locate “Windows Audio,” and see if it’s running. If it is, the status will show ‘Started’.
  5. No? Well guess what, iTunes needs this to be running in order to communicate with your audio device. Start it. There’s a link to start it along the leftmost column. Once it’s started, find a blank area within the services window, right click and hit refresh. Or just tap F5. Has the service died? If not, skip to step 7.
  6. The service died, didn’t it? Look for a ‘Windows Management Instrumentation’ service. This needs to be running for Windows Audio to be running, even though it’s not listed in the dependancies. Fire it up, then fire up Windows Audio.
  7. Fire up iTunes, and enjoy.
Secondly, you can open Control Panel and uninstall and then reinstall QuickTime. You can download QuickTime at this URL: http://www.apple.com/quicktime/download/
Third, you can try to reinstall iTune and allow any settings about playback and audio configuration with iTune during that.
Hope those helps.
Posted on Jul 09, 2010
Error message when logging into ITunes and audio will not play. "Itunes has detected a problem with your audio configuration. Audio/video playback may not operate properly." I have searched...
you should uninstall audio drivers then install the updated drivers for your audio.
then un-install iTunes and its all apple product using revo un-installer. that will ask to remove all the registry so while uninstalling the programme select all and delete them.
then download and install latest iTunes.
it will start working.
if it doesn't you can restore your computer to a previous date on which your itunes was working properly.
to do so.
click on Start >>>All Programms>>> Accessories>>System Tools>> System Restore>> Select the Date and Restore your Computer.
Enjoy!!
Jun 28, 2011 | Apple iTunes
Ipod touch 16gb will not restore. Every time i connect to itunes i get a message saying ''itunes has detected an ipod in recovery mode. You must restore this ipod before it can be used with itunes''. So i...
Sounds like it is trying to restore from a bad back up.
If I remeber correctly, you can select which back up to choose from, when the ipod is plugged into itunes and it pops up, right click on it and there should be a option to select which back up to pick from.
If not, google for the firmware (something like ipod touch <model) firmware. be a pretty big file, Under 200mb.
Once downloaded, plug your ipod in on your pc, then clcik restore while holding the 'shift' key, then select this fimrware file you downloaded.
It should be really easy as it is only one file, once done, youll have fresh new ipod. You will loose all your songs/ pics that are currently on there so be warned!
Feb 01, 2011 | Apple iPod touch
Itunes is detecting a problem with my audio configuration... my computer (laptop) wont play any sound at all. What should I do?
If you have audio managing software like Realtek, you can usually reset some options, and likewise, you can make adjustments from the audio and sounds menu in control panel. Most of the changes you can make are harmless and can be readily undone. iTunes could also just be acting stupid, like when it would screw up whenever I loaded AIM. You might want to see if there are some options that iTunes is set up with, which are causing the problem. When it gives you the message, saying it's detected a problem, see if you can read what it means by a problem. If you continue to have problems with iTunes, try using Winamp, it's a free download, and takes up little memory, and no spyware. Between those options, that should help resolve your problem.
Oct 23, 2009 | Gateway MX6920 Notebook
Hi - sound keeps on cutting out when playing itunes.
Try the following, it shuld fix the issue;
Open up Quicktime (if you cant find a .mov or .mpeg video file go to Program Files, Quicktime, QuickTimePlayer) go to Edit, Preferences>Quicktime Preferences and go to the audio tab, be sure to set everything as follows:
Rate: 192kHz
Channels:Set to be equal to the speaker setup you have Apply and then OK and close Quicktime and iTunes and then start up iTunes.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 09, 2009 | Tascam US-122 USB Audio/MIDI Interface...
Audio configuration problem
I would suggest u to the restore your computer because somebody or you might uninstall the sound card software by mistake. Go on start then all programs then accesories then system tools and then restore
Mar 17, 2009 | Microsoft Windows XP Professional
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
Sound driver
usually the sound card are built-in on the mobo(motherboard), try checking the model and brand of the mobo and download the sound/audio drivers of it.
You may want to check device manager and see if the computer detects that there is a audio controller on the system. then install the drivers.
Aug 22, 2008 | AMD Athlon 64 X2 3800+, 2.0 GHz Retail...
Volume problem
try turning up both the system volume (on your top menu bar, by your clock), and the itunes volume (in the itunes window), maybe one of them is set too low..?
Brad
Apr 09, 2008 | Apple PowerBook G4 Mac Notebook
No audio when i try to play tunes in itunes
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 23, 2007 | Adobe Photoshop 7.0 for PC
HP Compaq WF1907 Monitor Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
