Question about E-Machines Computers & Internet
When i turn on my computer after the icons appear, a screen comes on like iam trying to get on the internet even though i havent click the internet explorer button. the screen says it can't connect. so i just close that screen and the get on the regular way. this started about a month ago and i don't know what button a press to make it happen, but i would like to know what button a press to make it stop.
  • 78 Answers
It sounds exactly like you have a typical virus. Update your virus software, run a scan, and have it fix it for you. I am fairly certain that is what it is..
Posted on Jul 09, 2010
Apple wireless mouse will not work
1.Make sure your device is powered on.
2.If the LED is blinking, your device is in Discoverable Mode. If the LED is steady, your device is paired with another item. Unpair the device, turn it off, and start again.
3.In the menu bar of your Mac, choose the Bluetooth icon, then choose Open Bluetooth Preferences.
4.Your Mac scans for available Bluetooth devices.
5.When your device appears in the Bluetooth Preference Pane, click Pair.
Apr 07, 2017 | Apple Mouse
Compaq 610 windows 7 is unable to detect network
Click on the "Start" menu and selecting "Control Panel."Click on the icon that reads "hardware and Sound." Then, select the tab that reads "Bluetooth Devices." Click on the "Add" button. This will put your computer in "Search Mode." This means that it will search for any compatible Bluetooth devices in the area. Put your Bluetooth device in "Discovery Mode." This can be done by pressing and holding the button on the side of the device. This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop. Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 21, 2013 | HP Compaq 610 T5870 156 WH248UTABA...
I need to remove Driver Fetch from my laptop computer. I downloaded it, then uninstalled it, but it continues to appear when I log on, using Windows Vista. Two blue windows come up, the one in front says...
Dial Toll-Free 1 (800) 204-4427 We are here to help you with your computer update and optimization needs. Whether you need help with the Driver Support software
Apr 14, 2017 | Blitware Technology Driver Fetch
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
Hello
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
Cannot find my cd installer for hp deskjet d2360. trying to download for free installer. can anyone help?
If you have internet access go to hp downloads from google. If not, connect your printer to your PC (computer) turn it on. If your OS is XP the found new hardware balloon should appear above the icon on the task bar, click the balloon and the add new hardware wizard comes to the screen, read and follow prompts, as it will give you a list of some recent and current hp printer products to choose from. If the balloon as mentioned above does not appear, click start, click control panel, double click add hardware icon, and the add hardware wizard comes on screen, choose your options and follow the prompts. NOTE; if the printer has been installed on your computer previously, and your OS has not been altered (formatted) this is an easy task for the wizard, as there is a shadow copy of the necessary drivers stored in the memory of your hard drive. Hope this helps.
Jul 10, 2009 | HP Deskjet 2360 InkJet Printer
Wireless internet will not connect using WRT54G
Hi I am Vortash .. you will have to check your status in the bottom right of your screen ( usually two monitors with a flashing screen ) and if there is a red line through either then your not connected to your router as you thought . Double click on the monitor icons and then click network , you will see your Computer name your network icon then the Internet with a green line running through all ( if it is connected ) and the internet .On the left you will see manage wireless networks .click on that a screen will open and in the top right is a question mark click on that and a small window will appear click on click to open network there you will see your available wireless networks if the router is transmitting it will be there ... any queries and the last window you opened was the help window follow the instructions on there and you should get online ... You may have to open the directory of your router and reset it if it hasn't already .. that will be in the instructions in the router manual .. hope this helps regards Vortash
May 18, 2009 | Linksys Wireless-G WRT54G Router
No sound from laptop - no sound icon in bottom right of screen
HI,
The sound drivers on the laptop are missing . Install the latest sound drivers from the folllowing link
http://tinyurl.com/yu5kvy
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:\DELL\DRIVERS\R12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:\DELL\DRIVERS\R12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks Proton
Nov 27, 2008 | Dell Latitude D600 Notebook
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Blackberry curve--blackberry messenger problem
Try turning off your phone. Then remove battery. turn it back and turn it on. That does the trick most of the time. Dont forget to rate me. Thanks
Jan 10, 2008 | Cingular Wireless AT&T RIM BLACKBERRY BES...
I Dont know how to insert music into my player
I usually copy all my stuff to the root directory (the one that comes right after you clicked on the sansa icon in MY COMPUTER). If it still doesn't work maybe your USB port is damaged try the other one. Another option which I always recommend is to format the sansa by right clicking on its icon on MY COMPUTER and choosing Format. Let me know if it helped.
Jun 10, 2007 | SanDisk Sansa m250 MP3 Player
Computers & Internet Logo
22 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
