Question about Sony DAV-S300 System
I have the i-hd901 system can anyone tell how to hook it up. do i extra equipment
What wires i need to hook my i-hd901 home theater to my tv
Posted on Oct 06, 2010
Green hue from my Mitsubishi xl30u projector. Believe blue filter is shot. I have extra projector for parts. Can anyone tell me (pictures would help) what part to swap to fix this?
If you are skilled at aligning the LCD panels, go for it.
The Blue panel, nearest the light source, has been damaged by heat from an old bulb and needs replacing.
Feb 24, 2017 | Mitsubishi Office Equipment & Supplies
Ice machine not working in my new beko fridge GNE60520 DX, does anyone know how to rectify this problem
Is the water hooked up? New fridges don't usually come with the ice maker hookup it's extra, and most of the time they don't tell you that when you buy it, hope this helps?
Mar 03, 2015 | Beko Refrigerators
Can anyone tell me what the air blower on my pool equipment is?
The air blower on you equipment would supply air bubbles to yoor spa which when active sounds like a big vacuum
May 23, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Can you tell me if my sanyo dp42746 is capable of hooking up to netflix without buying something else? if so please tell me where to find the directions to hook netflix directly to the tv?
Hi, NETFLIX is an ONLINE service, the things your t.v. would need is an INTERNET connection, or a connection for P.C. ( also may be called V.G.A or D.V.I. ) If your t.v. has an internet connection it will be called a L.A.N. or W.A.N. connection ( it'll resemble a telephone jack ) hook this up to your internet. The easiest way however is to play NETFLIX through your P.C./laptop then view through the external monitor feature of computer. So unless you have a very simplified setup it should be possible to not buy extra equipment for NETFLIX. Good luck, and I hope this helped, Prodzilla
Apr 01, 2011 | Sanyo DP42746 42 in. Plasma Television
How do I hook the booster car seat up? What is
The "extra" belt w/ 2 hooks is for cars equipped with "LATCH" system. If your car is 2002 or newer, you should have it. Look for 1/2 inch dots in the seat fabric near the seat belts, feel just below it for a tiedown ring. I know it goes against guy rules, but maybe read the directions that came w/ your car seat. If you got it 2nd hand, go to walmart and read the directions on the floor models.
Mar 17, 2010 | Safety 1st Summit Booster Car Seat -...
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
High wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Jan 01, 2009 | Kicker KX650.4 Car Audio Amplifier
HOBART AM14F wiring diagram
I can tell you where the wires need to go.What are you trying to hook up on the dishwasher?
Feb 23, 2008 | Ovens
Sony DAV-S300 System Logo
1,005 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
