Question about RCA HD52W59 HDTV Projection Television
Double vision my picture has double vision, what causes that?
  • RCA Master
  • 8,617 Answers
Its usually caused by a failed FL231, DL231 and CL230. You can get the repair kit from www.tvrepairworld.com called the ITC222 & ITC222A convergence option missing repair kit. The kit contains the parts and the CD with instructions.
Posted on Jul 09, 2010
Technika TV bought April. 2013. Flickering picture and double vision appearance(as if 2 non aligned images). Same on DVD or Sky channels. Help.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 17, 2014 | Televison & Video
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Double vision picture picture is hazy
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 06, 2010 | RCA P55000 55" Rear Projection Television
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony SLV940HF
Since you have had this problem with other VCR's, it is very likely to be a problem with the connecting cables. Defective cables, or too many cables (daisy-chaining more than a few devices) can cause ghosting, which is what you're experiencing. Try a new set of cables from the TV to the VCR, and also from the VCR to any cable, satellite or outside antenna.
Jun 17, 2007 | Sony SLV-940HF VCR
RCA HD52W59 HDTV Projection Television Logo
266 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
