Confirming router settings - Computers & Internet
    Genius:
  • 3,587 Answers
Confirmed...what router?
Posted on Apr 19, 2008
Adsl flashing red light
talk to your isp supplier and confirm they are sending you signal... check the phone line to confirm signal (put a phone on and get tone).... reboot the router if that doesn't work set the router to default (button push) and see if that allows you to reprogram the router to your specs usually requires putting in a login user id and password
Nov 11, 2013 | Comtrend CT-520 Router
SET UP PASSWORD
Log in to the router's administrative console through a Web browser using the current password and username.
In the router's administrative console, navigate to the appropriate administration / security section where the password setting can be changed. In this example, the Administration tab at the top of the screen contains the Linksys router's password setting.
Choose a suitable password based on the standard guidelines for strong password security. Enter the new password in the Password box, and re-enter the same password a second time in the space provided. Entering the password a second time ensures you did not accidentally type in the wrong password the first time.
The password change is not applied on the router until you save or confirm the change. In this example, click the Save Settings button at the bottom of the page to have the new password take effect. You will see a confirmation window appear briefly to confirm the password change was made successfully. The new password takes effect immediately; rebooting the router is not required.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 15, 2013 | Edimax Computers & Internet
Changing the password
You want to change the password??
If yes the follow the given instructions::
Jan 16, 2013 | Linksys Wireless-N WRT150N Router
I want to change my password
Jan 13, 2013 | Motorola Computers & Internet
Change password in my router
Jan 10, 2013 | Computers & Internet
1 want to change my pasword
Jan 04, 2013 | Computers & Internet
All of my computers connect to the internet but my ps3 wont
Let's try the simplest things first. Restart the PS3. Then try restarting your router (unplug/replug it in). Make sure all the cables are nice and snug where they should be in both your router and the PS3.
If going for a wired connection, confirm that the cable to and port/cable slot on your router are good (try another cable and cable slot). If going for a wireless connection, confirm that other devices can access your router wirelessly.
Still having trouble? Check your internet settings on the PS3. Navigate to XMB > Settings > Network Settings > Internet Connection Settings. Run through it, selecting Automatic or Auto-Detect whenever possible. If that didn't work try setting it up manually. Here's a guide explaining each option of the manual set up process.
Hope this helps!
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
Problem with the D-Link AirPlus DI-524 Wireless Router: Keeps timing out on wireless and wired (PC) computers. Have had to unplug wireless router and turn modem off, then plug back in and turn modem back...
Connect to router with your browser and:
Check under Tools -> Time to confirm the router is synced to either the PC clock or a time server.
Check under Advanced - Filters (and firewall) to confirm the router is always on
Check under Home -> DHCP to confirm the lease time is set correctly
Oct 09, 2010 | D-Link AirPlus G DI-524 Wireless Router...
Laptop connection problems to wireless router after reformat
Hi Drew,
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Apr 03, 2009 | Linksys Wireless-G Broadband Router
No connection...lights not flashing
check CPE. ensure cables are good, confirm LAN and NIC is enabled. confirm that nic settings correct ie linkspeed and duplex settings, uninstall and reinstall if necessary
Dec 05, 2007 | Microsoft MN-700 Wireless Router (p5308j)
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
