Question about Boating
1995 Johnson 90hp ocean runner outboard motor no low idle
1995 Johnson 90hp ocean runner idles rough and will stall after a few seconds unless it is put into gear. Gas and oil are ok and fuel filter has been changed and the carbs cleaned as well as spark plugs changed. Still the same problem.
  • 66 Answers
SOURCE: 1995 Chevy K1500 4.3L V6. Engine has inconsistant idle
Have you changed the fuel pump yet?I had the same exact problem.I replaced my fuel pump with an AUTOZONE PIECE OF JUNK fuel pump.That pump lasted almost 2 days.The second day i had it the truck didnt want to start but it did and it ran like ****,and when i put it in gear it ran as long as I didnt touch that gas pedal.You could go get a fuel pressure test or just replace it,your call.You might want to check your filter too but im sure its the pump.Good luck
Posted on Apr 27, 2009
  • 187 Answers
SOURCE: outboard motor idles but will not speed up
You really have to blow out the jets to clear any varnish left over from lay up.
Posted on May 13, 2009
emissionwiz
  • 76164 Answers
SOURCE: 98 GMC k2500 7.4L Rouch Idle
TRY THIS BEFORE U SPEND ANYMORE MONEY N PARTS.
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Posted on May 22, 2009
  • 376 Answers
SOURCE: Hi/low idle
Ok. First do one thing. Remove the air cleaner and start the engine. With your finger, push against the side of the governor spring to raise the rpm's some and hold it there. Is the 'hunting' still there? The tab the spring is attached to adjusts the governor speed and being located where it is, is prone to being bumped while mowing, pushed in and lowering the engine speed. If it still surges, this is what I would do... Remove the fuel tank and carb assy.. Two bolts, one behind the gas cap and one on the end of the tank. Pull it straight off the intake pipe then unhook it from the throttle link. Now, empty the tank and unscrew the carb from the tank. Clean the carb with a can of carb cleaner. Slip the screen off the pickup and make sure it's clean. Discard the pump diaphragm and gasket. Buy a new pump diaphragm kit, part #795083. Clean the top of the tank where the pickup with the screen fits into. Put it back together. Remember to put the rubber diaphragm against the tank and the gasket on top of it then the carb. Don't forget to attach the breather tube when you're putting it back on the engine. That should fix 'er up. Also, if the rubber ring and plastic retainer ring came off on the intake pipe when you pulled the carb and tank off, snap them back in the end of the carb before sliding it back on the intake. Hope you can make sense of all this. Let me know how it goes. Dwain
Posted on Jun 29, 2009
stevenhurc
  • 450 Answers
SOURCE: 2000 Daewoo Lanos intermittently idles rough
check throttle body and pcv hoses and ports for blockage possible carbon build up and sticky iac valve
Posted on Jul 20, 2009
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Starts fine then stalls after a couple seconds.
its could be the fuel pump, if its going bad then it could be causing stall and a gas hose could be bad to and is only allowing a little gas to motor causing it to stall also
Aug 11, 2012 | 1998 Subaru Legacy
1994 90HP johnson outboard
Hi, your problem is simple you either have a head gasket gone or a exhaust plate/gasket gone. Either will let water into a cylinder which is why it ran ok without water. You should also check the water pump in the leg as you have now run it without water. Regards Phil.
Jun 20, 2012 | Boating
1995 Ford Escort LX, runs rough inconsistently, over 35mph it runs fine, under 35mph it is extremely rough, it is idling around 1000rpm - it used to idle around 500rmp. From an idle it is slow to get...
First of all there is a vacume leak, second how is the air filter?, tell the husband to change the MAF mass air flow sensor and I would also change the TEMP tempreature sensor.
Mar 02, 2011 | 1995 Ford Escort
1995 gmc jimmy-won't accelerate wants to stall
could be the fuel pump ...you will need to do a fuel pressure test on it ..the pressure should be 63 anything lower even so much as a few lbs will cause this to happen ...as well if it sat that long i would consider a complete tune up and check all vacuum lines for dry-rot
Sep 14, 2009 | 1995 GMC Jimmy
1995 safari van w stalls when giving it gas. changed fuel pump and filter. replaced egr valve. sometimes rough idle. when it stalls just like you turned off key. then when you try to start it acts like it...
maybe your iac valve is not working? it takes place of a choke or temp sender to computer could be bad which controls t I.A.C. known as the idle control valve,do you have any codes?
Sep 01, 2009 | 1995 GMC Safari
1996 90hp mercury idles rough
Try removing plug clean regap, change fuel filter add some carberator cleaner and moisture eleminator to the gas.
Aug 22, 2009 | Light Outboard Motor Boat Bass Fishing...
Apr 13, 2009 | 1997 Chevrolet K1500
Boating Logo
383 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
