Question about Precor C966i Treadmill (Used)
Just moved my precor c966i treadmill (we disassembled it down to the motor/treadmill part) and can't remember where the gray snap-in electronic connector that runs from the console down to the motor and electronics housing. Can you help me?
  • 15 Answers
It should be a cable that looks like an oversized telephone cable. I can't really tell by the description of the problem if you just can't remember where it plugs into or if you've lost it altogether. There will be a circuit board in the base of the treadmill that will have something that looks like a phone jack port on it. That's where it will plug into. There should only be one port on the lower board that will accept that style of plug.
Posted on Jul 09, 2010
Testimonial: "This is the exact answer to the problem--after much searching around, I finally found the little box it fit into. the treadmill is up and running. Thanks for your input."
We only get a STOP KEY and it will not run
c966 have Precor transported from one place to another place is not rash to give any signal in transcri could you help
Dec 16, 2015 | Precor C966i Treadmill C 966i
Where can I find a used lift motor for a Precor C966I treadmill? Part # on the motor is 6182A-1705080-01
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am not sure where you can find a used one, but I can find a couple of new options for you. Depending on your machine, there are two different motors available. One is for a 220V machine and the other is for 110V machine. I will post links to both.
MOTOR LIFT ACTUATOR 120V PRECOR TREADMILL PPP000000044257107 SPORTSMITH net
Lift Motor 240V Precor PPP000000044257108 SPORTSMITH net
Dec 22, 2014 | Precor C966i Commercial Treadmill Used
Precor error 15 input voltage
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
May 18, 2013 | Precor C966i Treadmill C 966i
We also have a precor c966 it stops sporadically. We have already had it serviced and put a new belt on it and the problem continues.
see the video and lube the deck belt+rollers bearing too.
Tight the drive belt motor.
test the motor see the diagram and go to my personal tips for motor helps.
Feb 27, 2013 | Precor C966i Treadmill (Used)
Speed sensor of DC Motor treadmill making noise.
the speed sensor NOT make noise, is the main motor see the diagram attached.However tight any connector or plug very well, and test the s. sensor for open or defective and replace. You can RUN the software calibration for easy diagnose, troubleshooting, and fix it.
You must test the input voltage motor, if there are the motor need repair, bearing, shaft, or winding defective.
God bless you
Nov 18, 2012 | Precor C966i Treadmill C 966i
Error 32
LUBE OR wax you deck belt, this happen for autoprotection electronic system. To due a lack of LUBE maintenance schedule.Do it right now according with owner manual.
2)lube THE rollers bearings too use WD-40 for the bearings only
3) Test the drive belt motor, for cracking or worn belt, replace or adjust in according.
4) Test the motor voltage input, if there are the motor need repair, see my personal TIPS for troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 16, 2012 | Precor C966i Treadmill C 966i
Precor C966i The unit turns off at random intervals. When reset it comes back on then shuts off a few minutes later. Error log is empty so not an error with software.
LUBE or wax the deck belt, this happen because you do not lube or wax your equipmente according with the schedule maintenance, you must do it, every week. Do it now.use 100% silicone lube-
2) LUBE the rollers bearing too use WD-40 for rollers b only.
3) Test the drive belt motor, and adjust it or replace
4) test the input voltage motor, if there are the motor need repair.see my personal TIPS for troubleshooting helps.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Nov 13, 2012 | Precor C966i Treadmill C 966i
Buttons stuck
Dear Sir:
I will help you , inmediately.
This problem is normally by the use. Go to radio Schak , and buy some Spray for to clean and lubricate electronic parts, contacts, buttons , or Spray for clean to pressure.
This will be fix it this problem.
Thank you in advance,sincerely. God bless you.
If you need further assistance please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 12, 2011 | Precor C966i Treadmill C 966i
The belt on my Precor C966i treadmill is not running and the display is flashing an "Error 22" message - what's the problem?
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Dec 24, 2010 | Precor C966i Treadmill C 966i
Need to disassemble a precor 9.31 to move to a new location. What tools do I need and how to do it?
Remove the motor shroud this is done with a set of allen wrenches, remove wire harness from the lower pcb, then on the console tower which is bolted to the frame with (should be ) 4 allen bolts on each side. Have a additional set of hands so that the upper tower does not tumble down.
Jun 29, 2010 | Precor 9.31 Treadmill
Precor C966i Treadmill (Used) Logo
253 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
