Question about Danby DAC9003D Air Conditioner
My danby unit is only blowing hot air and staying around 81 i have had this for about 9 years
  • Danby Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Ruud unit will not cool below 81
If the suction line is sweating and your air coming out of the registers is around 50deg. and you have condensate dripping from the indoor unit, then the unit is undersized.
If you dont feel any hot air coming out the top of the
outdoor unit,then either the compressor is not operating or you are low on refrigerant
Jun 16, 2010 | Ruud UBHC Air Conditioner
Does the exhaust go above or below the air intake?
above....hot air rises and will stay away from fresh air intake. If it were below it would short cycle through unit
May 18, 2010 | Danby DPAC8020 Air Conditioner
I can't seem to get the A/C to work. I'm thinking of getting a hose as a last resort. It seems to alternate blowing cool air, then hot air after a few minutes. There's also a tendency for the a/c to...
The symtoms you describe appear to indicate that the AC might be low on the freon charge. Usually blowing cold and then hot is the first sign that the unit is low on refridgerant and is working hard to keep cooling.
Further, the tripping of the breakers/electric power also indicates that the unit is working hard to cool and as a result is running hot and is causing the power to trip off. If you can get a AC tech to recharge the unit, you should be all set.
Here's a link to a site with the owners manual and a troubleshooting guide for your unit. You can access it for free.
http://www.retrevo.com/support/Danby-DPAC9030-Air-Conditioners-manual/id/886bh650/t/2/
Hope this helps you get things working again! Best Regards!
Jul 31, 2009 | Danby DPAC9030 Air Conditioner
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Unit blows only hot air after a few minutes. shuts off and on repeatly and seems to overheat.
Check the out flow tubing, Make sure that nothing is stopping it up and that it is as straight as possible. Hope this helps 2rns4u <*{{{>(
Jul 23, 2009 | Danby DPAC8020 Air Conditioner
Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Jul 02, 2009 | Danby DAC5020 Air Conditioner
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby propane refrigerator won't work. I've tried "burping" it for almost a year now with no success. Any suggestions? Is there a Danby service store in the southern or mid-Utah area or Grand...
Check if the orifice is clean.  If not, dissassemble, soak it in solvent and blow with pressurized air.  Do not put wire through the orifice as it will surely change the size and wreck the said part.
May 12, 2008 | Refrigerators
Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Jul 06, 2007 | Danby DPAC8020 Air Conditioner
Danby DAC9003D Air Conditioner Logo
132 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
